Hi Guys,
I have this library in python did it with Tkinter DB and I want from Arduino to retrieve data from database.db file for example : first name, second name and use them in IF function in Arduino, how to do this?
import sqlite3
from Tkinter import *
import tkMessageBox
import sys
import os
import serial
import time
class DB:
def __init__(self):
self.conn = sqlite3.connect("database.db")
self.cur = self.conn.cursor()
self.cur.execute(
"CREATE TABLE IF NOT EXISTS book (id INTEGER PRIMARY KEY, first TEXT, second TEXT, date INTEGER)")
self.conn.commit()
def __del__(self):
self.conn.close()
def view(self):
self.cur.execute("SELECT * FROM book")
rows = self.cur.fetchall()
return rows
def insert(self, first, second, date):
self.cur.execute("INSERT INTO book VALUES (NULL,?,?,?)", (first, second, date))
self.conn.commit()
self.view()
def update(self, id, first, second, date):
self.cur.execute("UPDATE book SET firtst=?, second=?, date=? WHERE id=?", (first, second, date, id))
self.view()
def delete(self, id):
self.cur.execute("DELETE FROM book WHERE id=?", (id,))
self.conn.commit()
self.view()
def search(self, first="", second="", date=""):
self.cur.execute("SELECT * FROM book WHERE first=? OR second=? OR date=?", (first, second, date))
return rows
db = DB()
def get_selected_row(event):
global selected_tuple
index = list1.curselection()[0]
selected_tuple = list1.get(index)
e1.delete(0, END)
e1.insert(END, selected_tuple[1])
e2.delete(0, END)
e2.insert(END, selected_tuple[2])
e3.delete(0, END)
e3.insert(END, selected_tuple[3])
def view_command():
list1.delete(0, END)
for row in db.view():
list1.insert(END, row)
def search_command():
for row in db.search(first_text.get(), second_text.get(), date_text.get()):
def add_command():
db.insert(first_text.get(), second_text.get(), date_text.get())
list1.insert(END, (first_text.get(), second_text.get(), date_text.get()))
def delete_command():
db.delete(selected_tuple[0])
def update_command():
db.update(selected_tuple[0], first_text.get(), second_text.get(), date_text.get())
def helloCallBack():
os.system('python twoservoslider.py')
B=Tkinter.Button(top,text="hello",command= helloCallBack)
B.pack()
window = Tk()
window.title("My Books")
def on_closing():
dd = db
if messagebox.askokcancel("Quit", "Do you want to quit?"):
window.destroy()
del dd
window.protocol("WM_DELETE_WINDOW", on_closing) # handle window closing
l1 = Label(window, text="First Name")
l1.grid(row=0, column=0)
l2 = Label(window, text="Second Name")
l2.grid(row=0, column=2)
l3 = Label(window, text="Date")
l3.grid(row=1, column=0)
first_text = StringVar()
e1 = Entry(window, textvariable=first_text)
e1.grid(row=0, column=1)
second_text = StringVar()
e2 = Entry(window, textvariable=second_text)
e2.grid(row=0, column=3)
date_text = StringVar()
e3 = Entry(window, textvariable=date_text)
e3.grid(row=1, column=1)
list1 = Listbox(window, height=6, width=35)
list1.grid(row=2, column=0, rowspan=6, columnspan=2)
sb1 = Scrollbar(window)
sb1.grid(row=2, column=2, rowspan=6)
list1.configure(yscrollcommand=sb1.set)
sb1.configure(command=list1.yview)
list1.bind('<<ListboxSelect>>', get_selected_row)
b1 = Button(window, text="View all", width=12, command=view_command)
b1.grid(row=2, column=3)
b2 = Button(window, text="Search entry", width=12, command=search_command)
b2.grid(row=3, column=3)
b3 = Button(window, text="Add entry", width=12, command=add_command)
b3.grid(row=4, column=3)
b4 = Button(window, text="Update selected", width=12, command=update_command)
b4.grid(row=5, column=3)
b5 = Button(window, text="Delete selected", width=12, command=delete_command)
b5.grid(row=6, column=3)
b6 = Button(window, text="Close", width=12, command=window.destroy)
b6.grid(row=7, column=3)
window.mainloop()
Thanks for all
