#ifndef __RTC_UPDATE_SIM800L__
#define __RTC_UPDATE_SIM800L__
#include "Pin_Configuration.hpp"
#include <HardwareSerial.h>
#define UART2 2
#define DEFAULT_VALUE 0
// TEST AT Command CONFIG - USE LIB
#define AT_COMM 1
#define SIM800_CODE 2
#define CONFIG_CODE AT_COMM
// TEST AT Command - USE LIB
#define Manual_UPDATE 20
#define SIM800_NTP_UPDATE 30
#define RTC_CODE Manual_UPDATE
// default
#define APN ""
#define APNN "TM"
#define USE ""
#define PASS ""
// VODAFONE
#define APN_VODF "internet.vodafone.net"
#define USE_VODF "internet"
#define PASS_VODF "internet"
// ORANGE // mobinilweb
#define APN_ORANG "internet.orange.ma"
#define APN_ORANGG "mms"
// mobinilweb
#define USE_ORANG "MEDINET"
#define PASS_ORANG "MEDINET"
// NTP SERVER
#define NTP_server "time.google.com"
// "pool.ntp.org" "196.44.136.162" 151.101.66.137
#define RTC_SERVER "ntppool.org"
#define RTC_server "https://www.ntppool.org"
#define PORT_NUM 80
// URL
#define URL_RTC "pool.ntp.org"
#define URL_TEST "https://jsonplaceholder.typicode.com/todos/1"
#define URL2_TEST "http://trapsnos.epcmms.com/api/Traps/LoadData2"
#define URL3_TEST "http://trapsnos.epcmms.com/api/Reading"
#define URL4_TEST "https://trapsysapi.epcmms.com/api/Lookups/GetAllCategories"
// CONTENT_TYPE
#define TYPE_CONTENT "application/json"
#define PAYLOAD_TYPE "{\"userId\": \"1\", \"id\": \"1\", \"title\": \"delectus aut autem\", \"completed\": \"false\"}"
#define DEBUG true
#if DEBUG == true
// Debug using serial
#define Debug_init(num) Serial.begin(num); // Serial Monitor for debugging
#define Debug(command) Serial.println(command); // Print the response for debugging
#define Debugline(command) Serial.print(command); // Print the response for debugging
#define Debug_RTC(command,string) Serial.println(command,string);
#endif
// function prototype
void Start_UDP_Connection_AT_COMMAND();
void getIP_AT_COMMAND();
void GPRS_CONNECTION();
void Setup_GPRS();
void Disconnect_GPRS();
void add_check_gprs();
// test functoin
void Setup_GPRS_AT_COMMAND();
void Debug_AT_Command_SHEHAB();
void AT_CHECK_COMMAND();
void GSM_Signal();
void Network_Registrution();
// test sms
void send_SMS();
void updateSerial();
void test_sim800_module();
void SetupGPRS();
void connect_check();
void setupModule();
void AT_Terminal_TEst();
void NTP_RTC_CONFIG();
long getTimeZoneOffset();
void HTTPs_TEST();
void fetchJSON();
void AT_UDP_Connection_SIM800L();
void Fetch_Time_Date();
void get_http_loop();
#endif /* __RTC_UPDATE_SIM800L__ */
here is code of sim800l
#include "RTC_Update_sim800l.hpp"
const char apn[] = APN; // Set your APN (e.g., Vodafone's APN)
const char user[] = USE; // Username for the APN (Usually empty)
const char pass[] = PASS; // Password for the APN (Usually empty)
const char* ntpServer = NTP_server; // NTP server
const char* rtcServer = RTC_server; // RTC server
const uint16_t ntpPort = PORT_NUM; // NTP server port
char num_of_repeat= DEFAULT_VALUE;
long g_getTimeZoneOffset= DEFAULT_VALUE;
const char URL[] = URL4_TEST;//RTC_server;//URL4_TEST;
const char CONTENT_TYPE[] = TYPE_CONTENT;
char PAYLOAD[50];
// // Define the serial communication for the SIM800L
#if CONFIG_CODE == SIM800_CODE
HardwareSerial SerialAT(UART2); // Use UART2 for communication with SIM800L
SIM800L* sim800l = new SIM800L((Stream *)&SerialAT, SIM800_RST_PIN, 200, 512);
#elif CONFIG_CODE == AT_COMM
static bool sendATCommand(String command, const int timeout);
* AT commands required (const char in PROGMEM to save memory usage)
const char AT_CMD_BASE[] PROGMEM = "AT"; // Basic AT command to check the link
const char AT_CMD_ECHO[] PROGMEM = "ATE1&W"; // Set command echo mode
const char AT_CMD_CPIN_TEST[] PROGMEM = "AT+CPIN?"; // Check SIM card status
const char AT_CMD_CPIN_PIN[] PROGMEM = "AT+CPIN="; // Configure PIN code
const char AT_CMD_CPIN_PIN_SET[] PROGMEM = "AT+CPIN=\"0000\""; // SET PIN code
const char AT_CMD_CSQ[] PROGMEM = "AT+CSQ"; // Check the signal strengh
const char AT_CMD_ATI[] PROGMEM = "ATI"; // Output version of the module
const char AT_CMD_GMR[] PROGMEM = "AT+GMR"; // Output version of the firmware
const char AT_CMD_SIM_CARD[] PROGMEM = "AT+CCID"; // Get Sim Card version
const char AT_CMD_CFUN_TEST[] PROGMEM = "AT+CFUN?"; // Check the current power mode
const char AT_CMD_CFUN0[] PROGMEM = "AT+CFUN=0"; // Switch minimum power mode
const char AT_CMD_CFUN1[] PROGMEM = "AT+CFUN=1"; // Switch normal power mode
const char AT_CMD_CFUN4[] PROGMEM = "AT+CFUN=4"; // Switch sleep power mode
const char AT_CMD_SAPBR_GPRS[] PROGMEM = "AT+SAPBR=3,1,\"Contype\",\"GPRS\""; // Configure the GPRS bearer
const char AT_CMD_SAPBR_APN[] PROGMEM = "AT+SAPBR=3,1,\"APN\","; // Configure the APN for the GPRS
const char AT_CMD_SAPBR_USER[] PROGMEM = "AT+SAPBR=3,1,\"USER\","; // Configure the USER for the GPRS (linked to APN)
const char AT_CMD_SAPBR_PWD[] PROGMEM = "AT+SAPBR=3,1,\"PWD\","; // Configure the PWD for the GPRS (linked to APN)
const char AT_CMD_SAPBR1[] PROGMEM = "AT+SAPBR=1,1"; // Connect GPRS
const char AT_CMD_SAPBR2[] PROGMEM = "AT+SAPBR=2,1"; // Check GPRS connection status
const char AT_CMD_SAPBR0[] PROGMEM = "AT+SAPBR=0,1"; // Disconnect GPRS
const char AT_CMD_CREG_TEST[] PROGMEM = "AT+CREG?"; // Check the network registration status
const char AT_CMD_CGATT_ATT[] PROGMEM = "AT+CGATT=1"; // Attach to GPRS
const char AT_CMD_CGATT_CHECK[] PROGMEM = "AT+CGATT?"; // CHECK GPRS
const char AT_CMD_CSTT_SETAPN[] PROGMEM = "AT+CSTT=CMNET"; // Start task and set APN.
const char AT_CMD_CIPSEND_UDP[] PROGMEM = "AT+CIPSEND"; // > SIM800 UDP test // SEND OK.
const char AT_CMD_CIPCLOSE_UDP[] PROGMEM = "AT+CIPCLOSE"; // > CLOSE SIM800 UDP
const char AT_CMD_CREG_APN[] PROGMEM = "AT+CSTT=\"\",\"internet.vodafone.net\",\"\""; // Set APN
const char AT_CMD_CIICR_TEST[] PROGMEM = "AT+CIICR"; // Bring up the GPRS connection
const char AT_CMD_CIFSR_TEST[] PROGMEM = "AT+CIFSR"; // Get the IP address
const char AT_CMD_CREG_DIS[] PROGMEM = "AT+CGATT=0"; // Disconnect GPRS
const char AT_CMD_HTTPINIT[] PROGMEM = "AT+HTTPINIT"; // Init HTTP connection
const char AT_CMD_HTTPPARA_CID[] PROGMEM = "AT+HTTPPARA=\"CID\",1"; // Connect HTTP through GPRS bearer
const char AT_CMD_HTTPPARA_URL[] PROGMEM = "AT+HTTPPARA=\"URL\","; // Define the URL to connect in HTTP
const char AT_CMD_HTTPPARA_USERDATA[] PROGMEM = "AT+HTTPPARA=\"USERDATA\","; // Define the header(s)
const char AT_CMD_HTTPPARA_CONTENT[] PROGMEM = "AT+HTTPPARA=\"CONTENT\","; // Define the content type for the HTTP POST
const char AT_CMD_HTTPPARA_REDIR[] PROGMEM = "AT+HTTPPARA=\"REDIR\",1"; // Enable HTTP redirection
const char AT_CMD_HTTPSSL_Y[] PROGMEM = "AT+HTTPSSL=1"; // Enable SSL for HTTP connection
const char AT_CMD_HTTPSSL_N[] PROGMEM = "AT+HTTPSSL=0"; // Disable SSL for HTTP connection
const char AT_CMD_HTTPACTION0[] PROGMEM = "AT+HTTPACTION=0"; // Launch HTTP GET action
const char AT_CMD_HTTPACTION1[] PROGMEM = "AT+HTTPACTION=1"; // Launch HTTP POST action
const char AT_CMD_HTTPREAD[] PROGMEM = "AT+HTTPREAD"; // Start reading HTTP return data
const char AT_CMD_HTTPTERM[] PROGMEM = "AT+HTTPTERM"; // Terminate HTTP connection
#endif
#if RTC_CODE == Manual_UPDATE
// Initialize Serial Monitor for debugging
while(!Serial);
// Initialize the hardware Serial1
SerialAT.begin(9600);
delay(2000);
fetchJSON();
delay(2000);
#elif RTC_CODE == SIM800_NTP_UPDATE
while(!Serial);
setupModule();
#endif
#if RTC_CODE == SIM800_NTP_UPDATE
get_http_loop();
#elif RTC_CODE == Manual_UPDATE
#endif
void setupModule() {
// Wait until the module is ready to accept AT commands
while(!sim800l->isReady() ) {
Serial.println(F("Problem to initialize AT command, retry in 1 sec"));
Serial.println(F("Setup Complete!"));
// Wait for the GSM signal
uint8_t signal = sim800l->getSignal();
while(signal <= 0 ) {
Serial.print(F("Signal OK (strenght: "));
Serial.print(signal);
Serial.println(F(")"));
// Wait for operator network registration (national or roaming network)
NetworkRegistration network = sim800l->getRegistrationStatus();
while(network != REGISTERED_HOME && network != REGISTERED_ROAMING ) {
Serial.println(F("Network registration OK"));
// Setup APN for GPRS configuration
bool success = sim800l->setupGPRS(APN);
while(!success) {
delay(5000);
Serial.println(F("GPRS config OK"));
void get_http_loop(){
// Establish GPRS connectivity (5 trials)
bool connected = false;
for(uint8_t i = 0; i < 5 && !connected; i++) {
connected = sim800l->connectGPRS();
// Check if connected, if not reset the module and setup the config again
if(connected) {
Serial.print(F("GPRS connected with IP "));
Serial.println(sim800l->getIP());
Serial.println(F("GPRS not connected !"));
Serial.println(F("Reset the module."));
sim800l->reset();
setupModule();
return;}
Serial.println(F("Start HTTP GET..."));
// Do HTTP GET communication with 10s for the timeout (read)
uint16_t rc = sim800l->doGet(URL, 10000);
if(rc == 200) {
// Success, output the data received on the serial
Serial.print(F("HTTP GET successful ("));
Serial.print(sim800l->getDataSizeReceived());
Serial.println(F(" bytes)"));
Serial.print(F("Received : "));
Serial.println(sim800l->getDataReceived());
// Failed...
Serial.print(F("HTTP GET error "));
Serial.println(rc);
g_getTimeZoneOffset = 3 * 3600; // UTC+4 during summer
// Set up the time using NTP server to sync
configTime(g_getTimeZoneOffset, 0,URL_RTC); // RTC_SERVER,RTC_SERVER
delay(5000);
// Sync with NTP periodically to keep time updated
struct tm currentTime;
if (getLocalTime(¤tTime)) {
Serial.println("Current Time from NTP:");
Serial.println(¤tTime, "%A, %B %d %Y %H:%M:%S");
Serial.println("Failed to get time from NTP");
// Close GPRS connectivity (5 trials)
bool disconnected = sim800l->disconnectGPRS();
disconnected = sim800l->disconnectGPRS();}
if(disconnected) {
Serial.println(F("GPRS disconnected !"));
Serial.println(F("GPRS still connected !"));}
// Go into low power mode
bool lowPowerMode = sim800l->setPowerMode(MINIMUM);
if(lowPowerMode) {
Serial.println(F("Module in low power mode"));
Serial.println(F("Failed to switch module to low power mode"));
// End of program... wait...
while(1);
void Setup_GPRS_AT_COMMAND() {
Debug(F("....................Setup GPRS....................."));
sendATCommand(AT_CMD_BASE, 1000); // Response should be OK
sendATCommand(AT_CMD_CPIN_TEST, 1000); // Response should be "READY"
sendATCommand(AT_CMD_CSQ, 1000); // The response should (e.g., +CSQ: <value>,<error_rate>)
sendATCommand(AT_CMD_CREG_TEST, 1000); // Response "+CREG: 0,1" indicates successful registration
if (!sendATCommand(AT_CMD_SAPBR1, 2000) || !sendATCommand(AT_CMD_CGATT_ATT,2000)) {
Debug("Retrying to open bearer...");
sendATCommand(AT_CMD_SAPBR0, 1000); // Close bearer
sendATCommand(AT_CMD_SAPBR1, 2000); // Reopen bearer
sendATCommand(AT_CMD_SAPBR_GPRS, 1000); // Set bearer profile
sendATCommand("AT+SAPBR=3,1,\"APN\",\"\"", 2000); // Set APN
sendATCommand("AT+SAPBR=3,1,\"USER\",\"\"", 2000); // Set username // AT_CMD_SAPBR_USER
sendATCommand("AT+SAPBR=3,1,\"PWD\",\"\"", 2000); // Set password // AT_CMD_SAPBR_PWD
// sendATCommand(AT_CMD_CIFSR_TEST, 2000);
sendATCommand(AT_CMD_SAPBR1, 2000); // Open bearer
sendATCommand(AT_CMD_SAPBR2, 2000); // Query bearer
// Check IP address response to confirm success
// sendATCommand("AT+CMEE=2", 1000); // Enable verbose error reporting
// sendATCommand(AT_CMD_SAPBR0,1000); // Disconnect GPRS
void fetchJSON() {
sendATCommand(AT_CMD_HTTPINIT, 2000); // Initialize HTTP
// sendATCommand("AT+HTTPSSL=1", 1000); // Initialize HTTP
sendATCommand("AT+HTTPPARA=\"CID\",1", 2000); // Set HTTP CID
sendATCommand("AT+HTTPPARA=\"URL\",\"https://trapsysapi.epcmms.com/api/Lookups/GetAllCountries\"", 1000); // Set URL
sendATCommand(AT_CMD_HTTPACTION0, 5000); // Send HTTP GET request
sendATCommand(AT_CMD_HTTPREAD, 2000); // Read response
sendATCommand(AT_CMD_HTTPTERM, 2000); // Terminate HTTP
// sendATCommand(AT_CMD_SAPBR0, 1000); // Close bearer
void Fetch_Time_Date(){
sendATCommand("AT+CCLK?\r\n", 3000);
sendATCommand("AT+CLTS=1\r\n",3000); // Get Local Timestamp
sendATCommand("AT&W\r\n",3000); // Get Local Timestamp
// Function to send AT command and wait for the response
static bool sendATCommand(String command, const int timeout) {
String response = "";
Debug("Sending: " + command);
SerialAT.println(command); // Send the command
unsigned long previousMillis = millis();
while (millis() - previousMillis < timeout) {
if (SerialAT.available()) {
char c = SerialAT.read();
response += c;
if (response.length() > 0) {
// Debugline("compare value : ");
// Debug(response.compareTo("ERROR"));
Debugline("Response: " + response);
return 1;
Debug("No response or timeout.");
return 0;
#endif
here is using wifi :
long g_getTimeZoneOffset= 0;
const char* ssid = "your-SSID"; // Replace with your WiFi network name
const char* password = "your-PASSWORD"; // Replace with your WiFi password
long getTimeZoneOffset() {
Serial.print("Current Month:");
Serial.println(currentTime.tm_mon +1);
} else { Serial.println("Failed to get time from NTP");}
// Serial.println(currentTime.tm_mon+1);
if(currentTime.tm_mon+1 == 12 || currentTime.tm_mon+1==1)
{return g_getTimeZoneOffset = 2 * 3600; } // UTC+2 during summer
return g_getTimeZoneOffset = 3 * 3600; // UTC+3 during summer
// Connect to WiFi
WiFi.begin(ssid, password);
Serial.println("Connecting to WiFi...");
Serial.print(".");}
Serial.println("Connected to WiFi!");
configTime(g_getTimeZoneOffset, 0, "pool.ntp.org");
delay(5000);
} else {Serial.println("Failed to get time from NTP");}
// Add your logic here, e.g., periodically update the time or use it for some task
delay(10000); // Wait 10 seconds before syncing again with NTP
// Update the time using NTP
Serial.println("Updated Time from NTP:");
