how to reverse byte array order?
so if my original array is
{..... , 0x20 ,0xB7 , 0xA2 , 0x22 , .....}
it will change it to
{.... 0x22 , 0xA2, 0xB7 , 0x20....}
Thanks ,
You rarly even need to do that except if you're stuck using some library/function you didn't make.
Otherwise, just reverse the order you loop through it :wink:
OK
I thought there is a reverse function (like in C# for list)
Thanks ,
No, you can make one for sure. But like I said, in most cases that’s just a wast to do.
byte Array[] = {..... , 0x20 ,0xB7 , 0xA2 , 0x22 , .....};
const ArrayLength = sizeof Array / sizeof Array[0];
  for (unsigned i = 0; i < ArrayLength/2; i++)
     byte temp = Array[i];
     Array[i] = Array[ArrayLength - 1 - i];
     Array[ArrayLength - 1 - i] = temp;
