How to Rewind the data in a SD file?
I can't find the function in SD.h to rewind the datalog from 1st-100th to 100th-1st.
I write some function to solve it.
First, I check how many lines in the data which I want to rewind, by counting '\n'.
Second, I use readStringUntil('\n') 100 times to store the 100th String in another file
and use the for loop the decline the times from 100 to 1.
it works when I rewind less than 12 lines,but it keeps showing "error opening reverse data" when I read 100 lines...
#include <SPI.h>
#include <SD.h>
const int chipSelect = 4;
while (!Serial) {
Serial.print("Initializing SD card...");
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
while (1);
Serial.println("card initialized.");
SD.remove("trackA.txt");
for (int i = 0; i < 100; i++) {
String dataString = "";
dataString = String(i+1);
File dataFile = SD.open("trackA.txt", FILE_WRITE);
if (dataFile) {
dataFile.println(dataString);
dataFile.close();
Serial.println(dataString);
else {
Serial.println("error opening datalog.txt");
int c;
c = Lines("trackA.txt");
Serial.println(c);
ReverseData("trackA.txt");
void loop(){
String readLine(String filename, int line){
String received = "";
File file = SD.open(filename);
if(file){
for(int i=0; i < line ; i++){
received = file.readStringUntil('\n');
return String(received);
file.close();
int Lines(String filename){
if (!(SD.exists(filename))) {
Serial.println("example.txt doesn't exist.");
int line = 0;
char ch;
if(file){
while(file.available()){
ch = file.read();
if(ch == '\n'){
line++;
file.close();
return line;
void ReverseData(String filename){
int c = Lines(filename);
String data_R = "R";
data_R += filename;
SD.remove(data_R);
for(int i = c; i >0 ; i--){
dataString = readLine(filename, i);
File dataFile = SD.open(data_R, FILE_WRITE);
if (dataFile) {
dataFile.print(dataString);
dataFile.close();
else {
Serial.println("error opening reverse data");
here is the code does any one could help me to find the problem?
or there is a better way to Rewind the data in a file ?
Every time you open an SD File or use a variable from the String class, you are allocating memory and Arduinos do not have garbage collection to recycle that used memory. I'm guessing your are running out. I would suggest looking at some of the SD examples and learn how to use C strings (arrays of char with a terminating '\0') rather than Strings.
Please edit your post to add code tags, as described in How to use this forum.
To "rewind" a data file on an SD card, simply close the file and reopen it.
The OP wants to "reverse" the line order of a file into another file. Not really a "rewind" operation
