How to round off the data and Store it into Memory for processing i am using a GPS data to Store it
Kindly help me out
Round off what data? GPSs return strings. You can't round a string. The string needs to be parsed and converted to numbers. You don't want to round the numbers when you store them in memory.
you are right but i am new to programming can u suggest me code by which i can Store my GPS reading in to EEPROM
I am not sure why you would want to store GPS data into EEPROM but the place to start looking at how to write the code is here:-
Could you explain what you mean by "round off the data" and "store it into memory for processing"?
It may be that you're trying to do something very easy, but from your question it isn't quite clear what that is.
basically what i am trying to do is to navigate my ride on Jeep through GPS the Problem i am facing is that its giving me continuous Lat\long i want to stop that and store it into EEPROM and then calculate the distance and bearing from my way point i am using NMEA library this is the method i am using if you have got any Knowledge regarding this Kindly let me know
You need to use a few of these. I've got some spares. Copy and paste these into your post. Then, maybe it will make sense.
Will your Arduino be running continuously during this journey, or do you want it to remember where it has been after you switch it off?
yes My Arduino will run continuously through the course from Destination to Waypoint
Then, every time you get a new position, you should update the distance and direction. There is no need to store any position in EEPROM.
But i dont know how can i fix the GPS data its continuously changing so for calculating the Distance and direction its not constant i can send you the the code
This assumption is invalid. The GPS returns new data often, but it does not return a continuous stream of data.
As far as the Arduino is concerned, there is an eternity between new readings.
Even better, post it.
// This is my first very simple GPS navigation tool, that
// was written for my Wiring board. It connects to a GPS
// module via port Serial1 (4800bps) and shows some very
// basic navigation information on a character-based LCD.
// The information shown is:
// - direction to destination, relative to own movement
// - distance to destination in meters (it is really
// easy to do kilometers, miles, etc.)
// - my current speed in kilometers per hour
// - GPS status identifier
// I tried it in my car, and it works perfectly, although
// it's quite useless. The code below uses the Wiring
// board diagnostic LED on pin 48, which does not exist
// on Arduino's -- be aware.
#include <math.h>
#include <nmea.h>
#include <LiquidCrystal.h>
#include <NewSoftSerial.h>
NewSoftSerial mygps(7, 8);
// create connection to GPRMC sentences from my GPS
NMEA myGPS(GPRMC);
// create LCD object (I use a 2x16 character display)
LiquidCrystal myLCD = LiquidCrystal(12, 11, 5, 4, 3, 2);
// my destination coordinates in signed degrees-decimal
float dest_latitude = 25.362023;
float dest_longitude = 68.355542;
//25.362023, 68.355542?
myLCD.begin(16,2);
mygps.begin(4800);
pinMode(13, OUTPUT); // diagnostic led on Wiring-board
myLCD.clear();
myLCD.home();
myLCD.print("GPS-NAV By Eshu");
// check if data from GPS available on Serial1 port
if (mygps.available() > 0 ) {
// check if full sentence recieved from GPS
if (myGPS.decode(mygps.read())) {
// if so, set status led on
digitalWrite(13, HIGH);
// calculate direction to destination, relative to my own direction of movement
float lat = myGPS.gprmc_latitude();
float longi = myGPS.gprmc_longitude();
myLCD.clear();
myLCD.home();
myLCD.setCursor(0, 0);
myLCD.print("lat:");
myLCD.print(lat);
myLCD.setCursor(0, 1);
myLCD.print("longi:");
myLCD.print(longi);
myLCD.setCursor(15, 1);
myLCD.print(myGPS.gprmc_status());
i am using the following code for the latitude and Longitude display on LCD
and the result is continuously varying and i am taking this code for my direction code that is
#include <math.h>
#include <nmea.h>
NMEA myGPS(GPRMC);
myLCD.begin(16,2);
mygps.begin(4800);
myLCD.clear();
myLCD.home();
float dir = myGPS.gprmc_course_to(dest_latitude, dest_longitude) - myGPS.gprmc_course();
if (dir < 0) { dir += 360; }
if (dir > 180) { dir -= 360; }
// display relative direction to destination
myLCD.clear();
myLCD.home();
if (dir < 0) {
myLCD.print('<'); // destination is to your left
myLCD.print('>'); // destination is to your right
myLCD.print(abs(dir), DEC);
myLCD.print(223, BYTE); // print °-character
// display distance to destination in meters
myLCD.print("D:");
myLCD.print(round(myGPS.gprmc_distance_to(dest_latitude, dest_longitude, MTR)));
myLCD.print("m");
// display my speed in kilometers per hour
myLCD.setCursor(5, 0);
myLCD.print("S:");
myLCD.print(round(myGPS.gprmc_speed(KMPH)),DEC);
myLCD.print("Km/h");
// display GPS positioning status ('A'=active, 'V'=void)
// set status led off
digitalWrite(13, LOW);
So what Arduino board are you using then?
So you check that there is at least one character in the buffer and then go on:-
To read a whole pile of bytes, how many I can't tell because I haven't got that library.
I think you need to wait until all the data is in before you try and read it.
If the NMEA library is anything like the TinyGPS library, only one byte is read, and then the decode() function is called. That function returns true or false, depending on whether the packet was completed by the last byte read.
OP: If you added a Serial.print() statement to loop, you'd see that there were thousands of passes through loop needed to collect one entire packet from the GPS. Each packet contains a timestamp. You'd see, if you printed the whole packet, that the time changes for each packet.
The code you posted is showing the direction to the destination already, so I'm not sure what it is you are asking for help with. It appears that all you need to do is to calculate the distance to the target.
NMEA is just like TinyGPS library but the difference is TinyGPS library doesn't gve course to and distane to feature where as NMEA do offer these refer the link below what i am referring
http://www.maartenlamers.com/nmea/
sir actually my output lat\long is continuously varying with the above code and hence the direction is varying so when the lat\long is fixed then it can give steady Direction to the destination
Sir i have found that the output i am getting is the timing error of the programming can u tell me is there any chances of My Programming mistake or so refer me a programme or Site from where i Accurate my GPS data
cutebuddy6:
I'm afraid I can't make sense of your question.
The only way to get a steady direction to the destination is to stop. I'm thinking that is what you need to do.
If you don't, the distance and direction from "here" to "there" is NOT going to be steady, for any value of "here" or "there".
its simple the LCD is showing 10 digit output of Lat and Long on the LCD and the the last digits are varying why ?
and how it can be solved?
