Most topics are asking about how to round to the right of the decimal, but I want to round to the nearest tens place instead, if that's possible. I'm using the tutorial Arduino Knob, but the servo is jumping from every small change, and I want to round my final value to reduce the jumping as much as possible.
Hi.
Divide the number by 10, do it round and multiply by 10.
RV mineirin
Arendodently?
Sorry,
round
I would add 5 before dividing by 10, else the result is floored instead of rounded
int result = ( ( number + 5 ) / 10 ) * 10
It didn't round my variable, BUT somehow it made the numbers jump less erratically, and it works fluently!
What do you mean ? Which type is your variable ? This code will work only for positive integers (as returned by analogRead)
#include <Servo.h>
Servo myservo; // create servo object to control a servo
int potpin = 0; // analog pin used to connect the potentiometer
int val = 0; // variable to read the value from the analog pin
int pot = 0;
myservo.attach(9); // attaches the servo on pin 9 to the servo object
pot = analogRead(potpin); // reads the value of the potentiometer (value between 0 and 1023)
val = ( ( pot + 5 ) / 10 ) * 10;
val = map(val, 600, 1020, 50, 180); // scale it to use it with the servo (value between 0 and 180)
myservo.write(val); // sets the servo position according to the scaled value
Serial.println(val);
delay(0); // waits for the servo to get there
The new code using the script you sent
Do it after map()
And your map() will return negative numbers so code need to be slightly modified.
Try:
val = map(pot, 600, 1020, 50, 180);
val = ( ( val + ( val > 0 ? 5 : -5 ) ) / 10 ) * 10;
Yup, works now!
