How to run a RPM sensor and pressure sensor together using a 20 x 4 lcd
Hi. I am trying to run both functions together for a model jet turbine and want to see both measurements simultaneously on one lcd. I have run both separately using a 16 x 2 lcd for each. can I combine the sketches.
Can I use this setup:
setupPart 1();
setupPart 2();
loopPart 1();
loopPart 2();
Where part 1 contains the code for the rpm sensor and part 2 the code for the pressure sensor.
What made you think that your question has anything to do with the Website and Forum section which is clearly stated to be for "Improvements for the web system, applications to moderator, spam, etc."? I have suggested to the Moderator to move it to the Programming section.
This sort of carelessness makes unnecessary work for the Moderators.
...R
@alfmarie
Your topic was Moved to it's current location / section as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
