I am new to Arduino, and need some help with a circuit that needs external power.
I have an Arduino Mega ADK or / and an Arduini UNO. I want to run a small vibration coin with it. It is specified here: http://www.sparkfun.com/datasheets/Robotics/310-101_datasheet.pdf
The vibration motor runs from 2-3.6V starting at 85mA with an internal 75Ohm terminal resistance.
I also have an NPN transsitor an some Diodes (Rectifier, Zener). Up to now I Understood ishould connect
The base is connected with an 1kOhm resistor to an output pin of the arduinio
The emitter is connected to the Arduino ground nearby the 5V pin
To collector is connected to the vibration motor. The vibration motor is connected to the arduini 5V pin
Is an external power supply really needed for this motor? What componenten are aditionally needed in the circuit? Do I need any more resistors? Any diodes?
still I have problems. I now try to makesome DC motors work after a tutorial. Can u answer me some questions here?
On picture 1 u can see my setup. This does not work since the board works up to 40mA. The DC motors runs on 4,5V (thats ok), but need 220 mA. So I want to try the approach on picture 2 with a transistor. Actually I do not use a battery, but I do use an external power supply. that is connected to the arduino power slot. Can you tell me how the setup needs to be done then?
Also when I can usw the DC motor I should be able to use the vibration motor as well?
but I think I need the 5V Pin from the Arduino? I have created the new setup wit the DC motor you can see on the screenshot. It actually does not work. Do you have any ideas why it does not work?
