How to run Flask App from Arduino Output
Hi!
I'm building an ATM with an Arduino and Coin Acceptor (CH-926) which should be connected to a Webapp, for what I'm using flask. Currently my problem is that I can only use my flask Webapp if I have inserted a coin into the Coin Acceptor, otherwise I can't proceed to my /getbitcoin/ route and get an "ERR_CONNECTION_REFUSED" .
I assume the Flask App can only run, if it gets an Output or High state from the Arduino.
I want to be able to go the the route and then insert the coins in the Coin Acceptor.
This is the Arduino Script I'm using:
const int coinSelector = A0; // Analog input pin that the coin selector uses
const int signalCostFactor = 5; // Each signal pulse is worth 5p
int signalValue = 0; // For storing value from analog input
int state; // Current state
int lastState = 0; // Last state
int balance = 0; // Pence
int coinValue = 0; // Curent coin value
int update = 1; // Used for sending an update
long updateDebounceTime = 0; // The last time we sent an update
long updateDebounceDelay = 500; // Update 500ms after last singal pulse
  pinMode(13, OUTPUT); // Status LED
  Serial.begin(9600); // Setup serial at 9600 baud
  delay(2000); // Don't start main loop until we're sure that the coin selector has started
  Serial.println("Ready..");
  signalValue = analogRead(coinSelector); // Read analog value from coin selector
  if (signalValue > 1000) {
    state = 1; // State is 1 as we're high
    state = 0;
    // Should we send a balance update
    if (update == 0) {
      if ((millis() - updateDebounceTime) > updateDebounceDelay) {
        Serial.print("Coin Value: ");
        Serial.println(coinValue); // WARNING: The coin value will be wrong if coins are inserted within the updateDebounceDelay, adjust the delay and test
        Serial.print("Balance: ");
        Serial.println(balance); // This should be the most accurate as we should get the same ammount of pulses even if multiple coins get inserted at once
        coinValue = 0; // Reset current coin value
        update = 1; // Make sure we don't run again, till next coin
  if (state != lastState) {
    // Process new signal
    if (state == 1) {
      digitalWrite(13, HIGH); // Turn status LED on to show signal
      balance = balance + signalCostFactor; // Update balance
      coinValue = coinValue + signalCostFactor; // Update coin value
      updateDebounceTime = millis(); // Update last time we processed a signal
      update = 0; // Time to send a update now?
      digitalWrite(13, LOW);  // Turn status LED off
    lastState = state; // Update last state
  delay(1);
And this is the Python/Flask Script:
from flask import Flask
from flask import render_template
import serial
app = Flask(__name__)
arduino = serial.Serial("/dev/tty.usbmodem411", 9600, timeout=1) # Connect to Arduino
@app.route("/")
def home():
    return render_template("home.html")
@app.route("/getbitcoin/")
def getbitcoin():
    value = arduino.readline()
    balance = arduino.readline()
    print(value.rstrip())
    print(balance.rstrip())
    return render_template("getbitcoin.html", balance = balance)
if __name__ == "__main__":
    app.run(port=5000, host='0.0.0.0', debug = True, use_reloader=True)
Let me know if I'm at the right forum for this question!
Thank you!
