Hi DaveX
I followed this link and modified my code. Although it doesn't show any error, when I ran the code, all the relay switches were turned on, and the Serial.print option was not working. I attached the modified code here. Would you please take a look at it?
#define valve1 23
#define valve2 22
#define valve3 25
#define valve4 24
#define valve5 27
#define valve6 26
#define valve7 29
#define valve8 28
#define valve9 47
#define valve10 46
#define valve11 49
#define valve12 48
int VWC1,VWC2,VWC3,VWC4,VWC5,VWC6,VWC7,VWC8,VWC9,VWC10,VWC11,VWC12;
float mV1,mV2,mV3,mV4,mV5,mV6,mV7,mV8,mV9,mV10,mV11,mV12;
float VWC_1,VWC_2,VWC_3,VWC_4,VWC_5,VWC_6,VWC_7,VWC_8,VWC_9,VWC_10,VWC_11,VWC_12;
int VWC_1_threshold = 25; int VWC_2_threshold = 50;
int VWC_3_threshold = 75; int VWC_4_threshold = 100;
int VWC_5_threshold = 25; int VWC_6_threshold = 50;
int VWC_7_threshold = 75; int VWC_8_threshold = 100;
int VWC_9_threshold = 25; int VWC_10_threshold = 50;
int VWC_11_threshold = 75; int VWC_12_threshold = 100;
unsigned long previousTime = millis();
long timeInterval = 30000;
pinMode(VWC1, INPUT); pinMode(VWC2, INPUT); pinMode(VWC3, INPUT); pinMode(VWC4, INPUT);
pinMode(VWC5, INPUT); pinMode(VWC6, INPUT); pinMode(VWC7, INPUT); pinMode(VWC8, INPUT);
pinMode(VWC9, INPUT); pinMode(VWC10, INPUT); pinMode(VWC11, INPUT); pinMode(VWC12, INPUT);
pinMode(valve1, OUTPUT); pinMode(valve2, OUTPUT); pinMode(valve3, OUTPUT);
pinMode(valve4, OUTPUT); pinMode(valve5, OUTPUT); pinMode(valve6, OUTPUT);
pinMode(valve7, OUTPUT); pinMode(valve8, OUTPUT); pinMode(valve9, OUTPUT);
pinMode(valve10, OUTPUT); pinMode(valve11, OUTPUT); pinMode(valve12, OUTPUT);
unsigned long currentTime = millis();
// valve 1
if(currentTime - previousTime > timeInterval) {
VWC1 = analogRead(A0); mV1 = (VWC1*5.0/(1024))*1000; VWC_1 = (((0.00211*mV1)-0.675)*100)-13.9;
if (VWC_1 < VWC_1_threshold) {
digitalWrite(valve1, LOW);
while (VWC_1 < VWC_1_threshold){
VWC1 = analogRead(A0); mV1 = (VWC1*5.0/(1024))*1000; VWC_1 = (((0.00211*mV1)-0.675)*100)-13.9;}
digitalWrite(valve1, HIGH);
else {
previousTime = currentTime;
// valve 2
VWC2 = analogRead(A1); mV2 = (VWC2*5.0/(1024))*1000; VWC_2 = (((0.00211*mV2)-0.675)*100)-13.9;
if (VWC_2 < VWC_2_threshold) {
digitalWrite(valve2, LOW);
while (VWC_2 < VWC_2_threshold){
VWC2 = analogRead(A1); mV2 = (VWC2*5.0/(1024))*1000; VWC_2 = (((0.00211*mV2)-0.675)*100)-13.9;}
digitalWrite(valve2, HIGH);
else {
// valve 3
VWC3 = analogRead(A2); mV3 = (VWC3*5.0/(1024))*1000; VWC_3 = (((0.00211*mV3)-0.675)*100)-13.9;
if (VWC_3 < VWC_3_threshold) {
digitalWrite(valve3, LOW);
while (VWC_3 < VWC_3_threshold){
VWC3 = analogRead(A2); mV3 = (VWC3*5.0/(1024))*1000; VWC_3 = (((0.00211*mV3)-0.675)*100)-13.9;}
digitalWrite(valve3, HIGH);
else {
// valve 4
VWC4 = analogRead(A3); mV4 = (VWC4*5.0/(1024))*1000; VWC_4 = (((0.00211*mV4)-0.675)*100)-13.9;
if (VWC_4 < VWC_4_threshold) {
digitalWrite(valve4, LOW);
while (VWC_4 < VWC_4_threshold){
VWC4 = analogRead(A3); mV4 = (VWC4*5.0/(1024))*1000; VWC_4 = (((0.00211*mV4)-0.675)*100)-13.9;}
digitalWrite(valve4, HIGH);
else {
// valve 5
VWC5 = analogRead(A4); mV5 = (VWC5*5.0/(1024))*1000; VWC_5 = (((0.00211*mV5)-0.675)*100)-13.9;
if (VWC_5 < VWC_5_threshold) {
digitalWrite(valve5, LOW);
while (VWC_5 < VWC_5_threshold){
VWC5 = analogRead(A4); mV5 = (VWC5*5.0/(1024))*1000; VWC_5 = (((0.00211*mV5)-0.675)*100)-13.9;}
digitalWrite(valve5, HIGH);
else {
// valve 6
VWC6 = analogRead(A5); mV6 = (VWC6*5.0/(1024))*1000; VWC_6 = (((0.00211*mV6)-0.675)*100)-13.9;
if (VWC_6 < VWC_6_threshold) {
digitalWrite(valve6, LOW);
while (VWC_6 < VWC_6_threshold){
VWC6 = analogRead(A5); mV6 = (VWC6*5.0/(1024))*1000; VWC_6 = (((0.00211*mV6)-0.675)*100)-13.9;}
digitalWrite(valve6, HIGH);
else {
// valve 7
VWC7 = analogRead(A6); mV7 = (VWC7*5.0/(1024))*1000; VWC_7 = (((0.00211*mV7)-0.675)*100)-13.9;
if (VWC_7 < VWC_7_threshold) {
digitalWrite(valve7, LOW);
while (VWC_7 < VWC_7_threshold){
VWC7 = analogRead(A6); mV7 = (VWC7*5.0/(1024))*1000; VWC_7 = (((0.00211*mV7)-0.675)*100)-13.9;}
digitalWrite(valve7, HIGH);
else {
// valve 8
VWC8 = analogRead(A7); mV8 = (VWC8*5.0/(1024))*1000; VWC_8 = (((0.00211*mV8)-0.675)*100)-13.9;
if (VWC_8 < VWC_8_threshold) {
digitalWrite(valve8, LOW);
while (VWC_8 < VWC_8_threshold){
VWC8 = analogRead(A7); mV8 = (VWC8*5.0/(1024))*1000; VWC_8 = (((0.00211*mV8)-0.675)*100)-13.9;}
else {
digitalWrite(valve8, HIGH);
// valve 9
VWC9 = analogRead(A8); mV9 = (VWC9*5.0/(1024))*1000; VWC_9 = (((0.00211*mV9)-0.675)*100)-13.9;
if (VWC_9 < VWC_9_threshold) {
digitalWrite(valve9, LOW);
while (VWC_9 < VWC_9_threshold){
VWC9 = analogRead(A8); mV9 = (VWC9*5.0/(1024))*1000; VWC_9 = (((0.00211*mV9)-0.675)*100)-13.9;}
digitalWrite(valve9, HIGH);
else {
// valve 10
VWC10 = analogRead(A9); mV10 = (VWC10*5.0/(1024))*1000; VWC_10 = (((0.00211*mV10)-0.675)*100)-13.9;
if (VWC_10 < VWC_10_threshold) {
digitalWrite(valve10, LOW);
while (VWC_10 < VWC_10_threshold){
VWC10 = analogRead(A9); mV10 = (VWC10*5.0/(1024))*1000; VWC_10 = (((0.00211*mV10)-0.675)*100)-13.9;}
digitalWrite(valve10, HIGH);
else {
// valve 11
VWC11 = analogRead(A10); mV11 = (VWC11*5.0/(1024))*1000; VWC_11 = (((0.00211*mV11)-0.675)*100)-13.9;
if (VWC_11 < VWC_11_threshold) {
digitalWrite(valve11, LOW);
VWC11 = analogRead(A10); mV11 = (VWC11*5.0/(1024))*1000; VWC_11 = (((0.00211*mV11)-0.675)*100)-13.9;}
digitalWrite(valve11, HIGH);
else {
// valve 12
VWC12 = analogRead(A11); mV12 = (VWC12*5.0/(1024))*1000; VWC_12 = (((0.00211*mV12)-0.675)*100)-13.9;
if (VWC_12 < VWC_12_threshold) {
digitalWrite(valve12, LOW);
while (VWC_12 < VWC_12_threshold){
VWC12 = analogRead(A11); mV12 = (VWC12*5.0/(1024))*1000; VWC_12 = (((0.00211*mV12)-0.675)*100)-13.9;}
digitalWrite(valve12, HIGH);
else {
// Data recording
if (currentTime - previousTime > timeInterval) {
Serial.print(VWC_1); Serial.print(" , ");
Serial.print(VWC_2); Serial.print(" , ");
Serial.print(VWC_3); Serial.print(" , ");
Serial.print(VWC_4); Serial.print(" , ");
Serial.print(VWC_5); Serial.print(" , ");
Serial.print(VWC_6); Serial.print(" , ");
Serial.print(VWC_7); Serial.print(" , ");
Serial.print(VWC_8); Serial.print(" , ");
Serial.print(VWC_9); Serial.print(" , ");
Serial.print(VWC_10); Serial.print(" , ");
Serial.print(VWC_11); Serial.print(" , ");
Serial.print(VWC_12); Serial.print(" , ");
