Hi i was struggling to run two stepper motors perfectly together as the library would only let me run one step per motor at a time. So i went through the library code and made a sketch that will run two steppers together or singly or inverted from each other “turning in opposite directions”. It only supports 4 wire stepper motors but if you glance at the Stepper library code you can easily convert it to run 5+ wires.
Any way here is the code “it could do with some minor touch ups to make it more efficient” but work fine as it is.
int step_number = 0;
int direction = 0;
unsigned long last_step_time = 0;
unsigned long step_delay;
unsigned long steps = 200;
const byte stepperOnePin_1 = 4;
const byte stepperOnePin_2 = 5;
const byte stepperOnePin_3 = 6;
const byte stepperOnePin_4 = 7;
const byte stepperTwoPin_1 = 8;
const byte stepperTwoPin_2 = 9;
const byte stepperTwoPin_3 = 10;
const byte stepperTwoPin_4 = 11;
int speed = 30; // 30 rmp
unsigned long currentMillis;
step_delay = ((60000UL / steps) / speed);
Serial.print("step_delay ");
Serial.println(step_delay);
stepTwo(200, true, true, false); // steps, select motor 1, select motor 2, invert directions "turn opposite direction to each other"
delay(3000); // not needed, just added to slow down loop !
stepTwo(-200, true, true, false); // now test the steppers in reverse
void stepTwo(int step, bool selectMotorOne, bool selectMotorTwo, bool invert) {
int steps_left = abs(step);
if (step > 0) {
direction = 1;
Serial.print("steps_left ");
Serial.println(steps_left);
else if (step < 0) {
direction = 0;
Serial.print("steps_right ");
while (steps_left > 0) {
currentMillis = millis();
if (currentMillis - last_step_time >= step_delay) {
//Serial.println("timer met");
last_step_time = currentMillis;
if (direction == 1)
step_number++;
if (step_number == steps) {
step_number = 0;
if (step_number == 0) {
step_number = steps;
step_number--;
// decrement the steps left:
steps_left--;
int thisStep = step_number % 4;
//Serial.println(step_number % 4);
if (!invert) {
switch (thisStep) {
case 0: // 1010
if (selectMotorOne) { // motor 1
digitalWrite(stepperOnePin_1, HIGH);
digitalWrite(stepperOnePin_2, LOW);
digitalWrite(stepperOnePin_3, HIGH);
digitalWrite(stepperOnePin_4, LOW);
if (selectMotorTwo) {// motor 2
digitalWrite(stepperTwoPin_1, HIGH);
digitalWrite(stepperTwoPin_2, LOW);
digitalWrite(stepperTwoPin_3, HIGH);
digitalWrite(stepperTwoPin_4, LOW);
case 1: // 0110
digitalWrite(stepperOnePin_1, LOW);
digitalWrite(stepperOnePin_2, HIGH);
digitalWrite(stepperTwoPin_1, LOW);
digitalWrite(stepperTwoPin_2, HIGH);
case 2: // 0101
digitalWrite(stepperOnePin_3, LOW);
digitalWrite(stepperOnePin_4, HIGH);
digitalWrite(stepperTwoPin_3, LOW);
digitalWrite(stepperTwoPin_4, HIGH);
case 3: // 1001
else {
Serial.println("inverted");
switch (thisStep) {
case 0: // 1001
case 1: // 0101
case 2: //0101
case 3: // 1001
