How to safely and reasonably convert a float or double to string or char array?
Correction to my suggested dtostrf
char* dtostrf (double __val, signed char __width, unsigned char __prec, char * __s, unsigned char __maxSize, bool __result)
__val: same as current dtostrf
__width: same as current arduino dtostrf
__prec: same as current arduino dtostrf
__s: same as current arduino dtostrf
__maxSize: The number of bytes allocated for this number
__result: true if the process was successful and maxSize was large enough. Return false if the size was not enough.
eturns the pointer to the converted string s. (this is used for sprintf and keep it compatible with what we have)
