How to save 9600 port to text file
I want to listen and save serial 9600 port to text file.
How can I do it?
do you want to have it save as it comes in, or just copy n paste a blob of data?
Download some free serial client program, lots of them can log data.
This looks good but I have no experience of it http://www.eltima.com/products/rs232-data-logger/
gyepesto: I want to listen and save serial 9600 port to text file.
What sort of serial port are you talking about?
If it's a TTL level serial port, you need something that can receive and log that - you could Ardulog or make your own equivalent with any Arduino.
If it's an RS232 signaling physical port you need a device that can receive RS232 - as above with an RS232 adapter.
If it's being received at a physical serial port or virtual serial port inside a PC then the options would depend what OS the PC is running, but various serial port terminal programs such as Realterm provide logging capabilities.
Please clarify:
Do you want to:
a) Read data being sent by an Arduino using your PC, and save it to a text file on your hard drive, or b) Read data being sent by some other device using an Arduino, and save it to a text file on an SD card?
The two things are radically different, so we need to know what you mean.
