how to save data from analog input writing them in an array?
:disappointed_relieved:
please, somebody help me
my code :
#define pin0 A0
#define pin1 A1
float kwh;
for (int thisPin = pin0; thisPin< pin1; thisPin++){
pinMode(thisPin,INPUT);
void loop(){
corriente();
void corriente(){
for (int thisPin = pin0; thisPin<pin1; thisPin++){ //read analog input
for(int i=10000; i>0; i--){ // SE HACE UN CONTEO PARA OBTENER UN PROMEDIO
sensorvalor = (analogRead(thisPin) -510);
valorSensor = valorSensor + pow(sensorvalor,2); //la suma del valor mas el valor elevado al cuadrado
valorSensor = (sqrt(valorSensor/ 10000)) * voltsporUnidad;
valorCorriente = (valorSensor/sensibilidad);
if(valorCorriente <= 0.095){ //SI LA CORIENTE ES MENOR A 0.095A, SE LE CONSIDERA 0A
valorCorriente = 0;
potencia = valorCorriente*tension;
kwh = (potencia * 1) /1000; // save values read in kwh
if (kwh<0.02){ kwh=0.00;}
//CALCULO PARA LA SUMA CONSECUTIVA
valorSensor =0;
Serial.println(kwh);
i'm trying to save values read (kwh) in an array so that I can display each one on the srceen when I request it.
for example:
float data[100];
in this array I want to save variable "kwh" and then:
data[0]= ? // I want to one value from A0 (kwh)
data[1]=?? //I want to second value from A1 (kwh)
ALISAYLI:
for example:
float data[100];
How you have started is not bad (if I have understood correctly):
float data[100];
data[0]= analogRead( A0 );  // I want to one value from A0 (kwh)
data[1]= analogRead( A1 );  //I want to second value from A1 (kwh)
// and then:
Serial.print(  "data[0]=" ) ; Serial.println (  data[0] ) ;
Serial.print(  "data[1]=" ) ; Serial.println (  data[1] ) ;
// etc.
bare in mind that an array of floats uses four bytes of memory for each entry. Your array of 100 floats takes 400 bytes.
@6v6gt , Thank You!
but i want to save "kwh" in an array... "kwh" is a result from sensor A0 and A1
Monitor serie:
//variable kwh
0.03 //A0
3.34 //A1
How I can to save kwh in an array so that I can display when I request it?
ALISAYLI:
@6v6gt , Thank You!
data[] is an array. What do you really mean?
aarg:
I want to save in an array each value:
Monitor serie:
//variable kwh
0.03 //A0
3.34 //A1
:frowning:
Please post your code in code tags
#define pin0 A0  //A0 ==14
#define pin1 A1  //A1 ==15
You have this following statement twice in you code
Your for loops are never working with pin1. Change it to
[code]for (int thisPin = pin0; thisPin<=pin1; thisPin++)
Why do you need 10000 readings? Rather than using pow, I would use use sensorvalor*sensorvalor. How are your variables defined? Please post complete code.
How many times do you want to save each pair of values ?
I want to do something like this;
  valorSensor =0;
float datos[100];
 datos[inkw]=kwh; //array to save kwh
 k0=datos[0]; //analog A0
 Serial.println(k0);
 k1=datos[1];  //analog A1
Serial.println(datos[1]);
but I've problems because "k0" only to save values from A0 and A1.. k1 doesn't does anything
No, sorry, don't understand.
Edit: deleting the incomprehensible post helps no-one
Code: [Select]
valorSensor =0;
float datos[100];
Serial.println(k0);
but I've problems because "k0" only to save values of A0 and A1.. k1 doesn't does anything
I restored the posts you accidentally deleted.
valorSensor =0;
float datos[100];
Serial.println(k0);
Please see reply #8.
What is"inkw"?
Please stop deleting posts - you can edit them instead.
My code:
#define pin0 A0
#define pin1 A1
#define pin2 A2
float inAn[100], ink;
//float inAn[]={A0,A1,A2,A3,A4};
int inkw;
float k0,k1,k2,k3,k4,k5;
float dutyCycle;
String cadena ="";
int sensorvalor = 0;
float valorSensor = 0,valorCorriente = 0;
float voltsporUnidad = 0.0032258064516129032258064516129; //para teensy 3.3/1023;  //para arduino 0.004887585532746823069403714565;// 5%1023
float watts = 0, kwh=0;
float sensibilidad = 0.066; // ACS712_30 A
int tension = 127;  //
 for (int thisPin = pin0; thisPin<pin2; thisPin++){
      sensorvalor = (analogRead(thisPin) -509);  //
      valorCorriente = 0;
  watts = valorCorriente*tension;
  kwh = (watts * 1) /1000;
  if (kwh<0.02) kwh=0.00;
  inkw=kwh;
 valorSensor =0;
 inAn[inkw]=kwh; //array to save kwh
 k0=inAn[0]; //analog A0
 Serial.println(k0);
 k1=inAn[1];  //analog A1
// Serial.println(k1);
 //delay(500);
    inkw = kwh;
    valorSensor = 0;
    inAn[inkw] = kwh; //array to save kwh
This is not right. The inAn array is declared to hold 100 values in locations numbered 0 to 99. To do what you want to save 2 values you need to read the first value, do any calculations and save the result ro anAn[0]. Then read the second value, do any calculations and save the result to anAn[1] and so on.
