How to save mp3 file in sd card from api using esp32
Hi everyone, I am working on a project where I have to save the mp3 file from custom API to sd card and after that play it using esp32 where I am using VS1053B Codec.
I have seen plenty of examples of internet radio which are playing audio through differrent web stations.
If anyone has solution for my problem, please let me know
Regards
Rajbir
What/where is the problem?
here is the code
#include <WiFi.h>
#include <HTTPClient.h>
#include <Arduino_JSON.h>
const char* ssid = "MYACCESSPOINT";
const char* password = "MYPASSWORD";
//Your Domain name with URL path or IP address with path
String serverName = "MYAPI";
// the following variables are unsigned longs because the time, measured in
// milliseconds, will quickly become a bigger number than can be stored in an int.
unsigned long lastTime = 0;
// Timer set to 10 minutes (600000)
//unsigned long timerDelay = 600000;
// Set timer to 5 seconds (5000)
unsigned long timerDelay = 5000;
String AUDIO_STRING ;
String AUDIO_STRING Arr[100];
  WiFi.begin(ssid, password);
  Serial.println("Connecting");
  while(WiFi.status() != WL_CONNECTED) {
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to WiFi network with IP Address: ");
  Serial.println("Timer set to 5 seconds (timerDelay variable), it will take 5 seconds before publishing the first reading.");
  //Send an HTTP POST request every 10 minutes
  if ((millis() - lastTime) > timerDelay) {
    //Check WiFi connection status
    if(WiFi.status()== WL_CONNECTED){
      AUDIO_STRING = httpGETRequest(serverName);
      Serial.println(AUDIO_STRING );
    else {
      Serial.println("WiFi Disconnected");
    lastTime = millis();
String httpGETRequest(String serverName) {
  WiFiClient client;
  HTTPClient http;
  String serverPath = serverName + "?MYAPIPATH";
  // Your Domain name with URL path or IP address with path
  http.begin(serverPath.c_str());
  // Send HTTP POST request
  int httpResponseCode = http.GET();
  String payload = "{}";
  if (httpResponseCode>0) {
    Serial.print("HTTP Response code: ");
    Serial.println(httpResponseCode);
    payload = http.getString();
  else {
    Serial.print("Error code: ");
  // Free resources
  http.end();
  return payload;
here is the reply
Basically I want to get the audio from My custom API and want to play on speaker using esp32.
but i am getting this string data but don't know how to convert it in playable audio.
1.zip (17.0 KB)
This is the audio file I want to convert.
Please help me solve.
I also got this lib to play the audio
Please help if anyone is having the solution.
