How to save SRAM
I am trying some example with ESP8266.Everything works well but I want save more SRAM and use PROGMEM function instead.
Can someone help how to do it with this piece of the code?
void serve_homepage(char ClientId) {
  String header  = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n";
  String content = "";
  content += "<p>WLAN Setup</p>";
  content += "<form method=GET>";
  content += "<label>SSID</label>
  content += "<input type='text'name='ssid'maxlength='30'size='15'>
  content += "<label>Password</label>
  content += "<input type='password'name='pass'maxlength='30'size='15'>
  content += "<input type='submit'value='CONNECT'>";
  content += "</form>";
  header  += "Content-Length:";
  header  += (int)(content.length());
  header  += "\r\n\r\n";
  Serial.print(F("AT+CIPSEND="));
  Serial.print(ClientId);
  Serial.print(",");
  Serial.println(header.length()+content.length());
  if(get_response("> ",2000)) {
    Serial.print(header);
    Serial.print(content);
  else {
    Serial.print(F("AT+CIPCLOSE="));
    Serial.println(ClientId);
I tried this but it does not works - page is not loaded.
const char *const content PROGMEM  =
"<form method=GET>"
"</form>";
  header  += (int)strlen(content);
  Serial.print(F(","));
  Serial.println(header.length()+strlen(content));
    Serial.print(*content);
  else {
Can somebody help?
ppt
Hello and welcome,
Take a look at the progmem examples
Best advice is to rewrite your code without using the String Class and use char array's instead.
These can be easily stored in PROGMEM. - PROGMEM - Arduino Reference -
Hi Rob,
Can you please show on my code how to use char arrays?
I am beginner so I don't understand this technique so much...
It would be useful also for another users of this forum.
ppt
See also https://www.baldengineer.com/arduino-f-macro.html
finally I got it working by this modification:
const  char string_0[] PROGMEM =  "<form method=GET>";
const  char string_1[] PROGMEM =  "<label>SSID</label>
const  char string_2[] PROGMEM =  "<input type='text'name='ssid'maxlength='30'size='15'>
const  char string_3[] PROGMEM =  "<label>Password</label>
const  char string_4[] PROGMEM =  "<input type='password'name='pass'maxlength='30'size='15'>
const  char string_5[] PROGMEM =  "<input type='submit'value='CONNECT'>";
const  char string_6[] PROGMEM =  "</form>";
const char* const content[] PROGMEM= {string_0 ,string_1 ,string_2 ,string_3 ,string_4 ,string_5 ,string_6 };
  header  += 232;                  //  (sizeof(content)/sizeof(char *));
  Serial.println(header.length()+232);  //Serial.println(header.length()+strlen(content));
    unsigned int count = 0;
    for (int i = 0; i < 7; i++){
      char * ptr = (char *) pgm_read_word (&content [i]);
      char buffer [500]; // must be large enough!
      strcpy_P (buffer, ptr);
      Serial.print (buffer);
      count += strlen (buffer) + 1;
  else {
But another problem is how to calculate size of array 'content'.
for me works only this (gives 232):
Serial.println(strlen(content[0])+ strlen(content[1])+ strlen(content[2])+ strlen(content[3])+ strlen(content[4])+ strlen(content[5])+ strlen(content[6]));
but this one not works:(gives unrealistic numbers)
   for (int i = 0;i < 7;i++){
    cc = cc + strlen(content[i]);
    Serial.println(cc);
can someone help why???my Arduino is latest 1.65.
thanks!
strlen_P ?
can you more explain?
ppt
Here
The variable content[] is an array of pointers to your string arrays. Because each pointer requires 2 bytes and you have 7 of them, the size of content[] is 14, which I don't think is what you want. Also, you're mixing Strings (i.e., in header) with strings (content[]). (Note that Strings with a capital 'S' is not the same as strings with a lower case 's'.)
can you please write some example for me?
I didn't found anything what I can understand on the web.
ppt
