for (long X = 0 ; X <= 200; X += 1.0) {
float c = sqrt(X * X + pow((h - Y), 2));
float angle = degrees(atan2(X, (h - Y)));
ThighStart = ThighStart - angle;
for (long X = 200 ; X >= 0; X -= 1.0){
float c = sqrt(X * X + pow(h , 2));
float angle = degrees(atan2(X, h));
ThighStart = ThighStart + angle
In the second loop for-function, where the value is decreasing from 200 to 0, I want the last value of ,, ThighStart" at X = 200 in the first loop for-function as its input (Start value). How do I do that?
Not sure what you are asking. ThighStart will be at the value it was for the last iteration of the first for loop when you enter the second for loop. BTW, for is not a "function".
A couple of comments:
X in both loops is a long type. You could use an int type, however. Either way you should be incrementing by 1 not 1.0 since it is an integer.
You realize both for loops are executing 201 iterations, not 200?
I am saying that in the first for loop, test the value of "X" for being 199, the 200th pass through the loop. When equal to 199, save the value of ThingStart in a new float.
Then just before beginning the second "FOR", move the saved value back into ThingStart. That gives you the value from the 200 pass through the first "for" loop.
Without the complete code it is hard to follow where your problem is ...
Would you mind (at least) to post the code with the startvalues of ThighStart, Y and h as well as where you have put the Serial.print()s of ThighStart (in which lines)?
Though you and @westfw are right regarding the variable X, it looks as if the TO is not concerned about X rather than the variable "ThighStart" ...
However, as long as we do not have the complete information about the algorithms the TO posted, it is only guess work
If you read post # 4 in this thread the intention of the TO might become more clear (unless this was a misleading phrase):
I suspect that it may depend on where the println() was introduced:
// If printed here: ThighStart should be like before
if (X == 200) Serial.println(ThighStart);
ThighStart = ThighStart + angle;
// If printed here: ThighStart has been increased by angle
As long as the TO does not give further information - as stated before by me - we can only guess ...
And in the posted part
a colon is missing at the end after "ThighStart + angle"
the variable c is only calculated but never used
the value of variable h is unknown to us
the value of variable Y is unknown to us (which is not required if we believe that the value of ThighStart is 136.83 after the first for loop)
int i = 0;
First loop, can also be done as a while loop
since we have initialised i to zero above.
See the while loop version below
for(i = 0; i < 10; i++)
//Loop exits when i becomes 10
//Note that i++ is "post incremented"
//i is first used and then increased by 1
//At this point i equals 10
int j = i; // j now has a value of 10
//Second loop
while (j < 20)
//Loop exits when j becomes 20
j++;
Thread Owner, the one who started the actual thread ... In this case it is you ...
It would be helpful if you could post some more of your code, in minimum an excerpt that can be compiled and includes all relevant variables and algorithms. Unfortunately (see my post above) the part which you published in the first post does not fulfill these minimum requirements.
Do you think you could create a short sketch that includes all necessary data and algorithms so that one can retrace what's going on?
