How to save the value bigger than 255 to external EEPROM
helo, I need help with this ... this coding is function .. but i want to store my data value is more than 255... problem of this coding is when i enter my value is greater than 255 , the return data is different...
#include "Wire.h"
#define EEPROM_I2C_ADDRESS 0x57
  Wire.begin();
  int address = 0;
  byte val = 110;
  writeAddress(address, val);
  byte readVal = readAddress(address);
  Serial.print("The returned value is ");
  Serial.println(readVal);
void writeAddress(int address, byte val)
  Wire.beginTransmission(EEPROM_I2C_ADDRESS);
  Wire.write((int)(address >> 8));   // MSB
  Wire.write((int)(address & 0xFF)); // LSB
  Wire.write(val);
  Wire.endTransmission();
  delay(5);
byte readAddress(int address)
  byte rData = 0xFF;
  Wire.requestFrom(EEPROM_I2C_ADDRESS, 1);
  rData =  Wire.read();
  return rData;
You can use lowByte and highByte to split an int. You can use shift operations (>>) and logical and (&) to split longs.
i am new in this ... can you show me a example of it?
  Wire.write(val);
  delay(5);
this coding not already split???
In your example you are splitting the address, not the value.
Did you look at the library examples or the examples in this site ?
A quick look shows them writing different variable types.
thank you for that..
what example should i search for ?
cause i spend quite a lot of time to search ... but i din get the things i want... or what should i key so that i can get the wrong method for me as references??
most of the method they split the address...
GarethMoffatt:
Why not use EEPROM.put() and EEPROM.get() ?
You are talking about external EEPROM. Which is the type? AT24C32 or ATC512. Let us take the example of AT24C32. Go to this link, you will find various examples for performing data read/write operations with this external
EEPROM.
The 24C32 EEPROM contains 4096 locations; each location can hold 8-bit data. The data read/write operations can be done using one of the following methods:
1. Using I2C Bus Commands.
2. AT24CX.h Library Functions. The deviceAddress is fixed at 0x50 in the H-file.
* Read and write demo of the AT24CX library
* Written by Christian Paul, 2014-11-24
// include libraries
#include <Wire.h>
#include <AT24CX.h>
// EEPROM object
AT24CX mem;
// setup
  // serial init
  Serial.println("AT24CX read/write demo");
  Serial.println("----------------------");
// main loop
  // read and write byte
  Serial.println("Write 42 to address 12");
  mem.write(12, 42);
  Serial.println("Read byte from address 12 ...");
  byte b = mem.read(12);
  Serial.print("... read: ");
  Serial.println(b, DEC);
  // read and write integer
  Serial.println("Write 65000 to address 15");
  mem.writeInt(15, 65000);
  Serial.println("Read integer from address 15 ...");
  unsigned int i = mem.readInt(15);
  Serial.println(i, DEC);
  // read and write long
  Serial.println("Write 3293732729 to address 20");
  mem.writeLong(20, 3293732729UL);
  Serial.println("Read long from address 20 ...");
  unsigned long l = mem.readLong(20);
  Serial.println(l, DEC);
  Serial.println("Write 1111111111 to address 31");
  mem.writeLong(31, 1111111111);
  Serial.println("Read long from address 31 ...");
  unsigned long l2 = mem.readLong(31);
  Serial.println(l2, DEC);
  // read and write float
  Serial.println("Write 3.14 to address 40");
  mem.writeFloat(40, 3.14);
  Serial.println("Read float from address 40 ...");
  float f = mem.readFloat(40);
  Serial.println(f, DEC);
  // read and write double
  Serial.println("Write 3.14159265359 to address 50");
  mem.writeDouble(50, 3.14159265359);
  Serial.println("Read double from address 50 ...");
  double d = mem.readDouble(50);
  Serial.println(d, DEC);
  // read and write char
  Serial.print("Write chars: '");
  char msg[] = "This is a message";
  Serial.print(msg);
  Serial.println("' to address 200");
  mem.writeChars(200, msg, sizeof(msg));
  Serial.println("Read chars from address 200 ...");
  char msg2[30];
  mem.readChars(200, msg2, sizeof(msg2));
  Serial.print("... read: '");
  Serial.print(msg2);
  Serial.println("'");
  // write array of bytes
  Serial.println("Write array of 80 bytes at address 1000");
  byte xy[] = {0,0,0,1,1,1,2,2,2,3,3,3,4,4,4,5,5,5,6,6,6,7,7,7,8,8,8,9,9,9,    // 10 x 3 = 30
              10,11,12,13,14,15,16,17,18,19,                                   //          10
              120,121,122,123,124,125,126,127,128,129,                         //          10
              130,131,132,133,134,135,136,137,138,139,                         //          10
              200,201,202,203,204,205,206,207,208,209,210,211,212,213,214,215,216,217,218,219};                   //          20
  mem.write(1000, (byte*)xy, sizeof(xy));
  // read bytes with multiple steps
  Serial.println("Read 80 single bytes starting at address 1000");
  for (int i=0; i<sizeof(xy); i++) {
    byte sb = mem.read(1000+i);
    Serial.print("[");
    Serial.print(1000+i);
    Serial.print("] = ");
    Serial.println(sb);
  // read bytes with one step
  Serial.println("Read 80 bytes with one operation at address 1000");
  byte z[80];
  memset(&z[0], 32, sizeof(z));
  mem.read(1000, z, sizeof(z));
  for (int i=0; i<sizeof(z); i++) {
    Serial.print("[");
    Serial.println(z[i]);
  // stop
  while (1==1) {}
ok ... let me try figure it out again .. thank you
septillion:
External eeprom :wink:
Sorry! Missed that! :frowning:
Time for an external memory library with support for .get() and .put() :sunglasses:
