How to save value to variable?
Hi, i will post code here. I want to make variable from 0 or 1 it consist .txt file. I can change value throught PHP script. But, in my .ino file there is char c, but char c are all charts with HTTP header too.
How can i make something like if in txt = 1 for instance: pin, HIGH and if in txt = 0 for incence: pin, LOW
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128);  // numeric IP for Google (no DNS)
char server[] = "www.arduino.php5.sk";    // name address for Google (using DNS)
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192, 168, 1, 254);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // try to congifure using IP address instead of DHCP:
    Ethernet.begin(mac, ip);
  // give the Ethernet shield a second to initialize:
  Serial.println("connecting...");
  // if you get a connection, report back via serial:
  if (client.connect(server, 80)) {
    Serial.println("connected");
    // Make a HTTP request:
    client.println("GET /lumino/readme.txt HTTP/1.1");
    client.println("Host: www.arduino.php5.sk");
    client.println("Connection: close");
    client.println();
    // if you didn't get a connection to the server:
    Serial.println("connection failed");
  // if there are incoming bytes available
  // from the server, read them and print them:
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    Serial.println("disconnecting.");
    client.stop();
    // do nothing forevermore:
    while (true);
Please post in the international section for your native language with a link to this post. Your English isn't good enough for us to have any hope of communicating with you at the necessary level.
martinius96: How can i make something like if in txt = 1 for instance: pin, HIGH and if in txt = 0 for incence: pin, LOW
That seems easy to understand but I'm not sure how to relate it to the code you posted.
Is what you want something like this ?
    Serial.print(c);
    if (c == '1') {
       digitalWrite(pin, HIGH);
    else if (c == '0') {
       digitalWrite(pin, LOW);
If I have got it all wrong, please explain your requirement more clearly.
...R
