How to scale to 8 bits
In the tutorials:
I found the sample code:
This function will read a sensor five times with analogRead() and calculate the average of five readings. It then scales the data to 8 bits (0-255), and inverts it, returning the inverted result.
int ReadSens_and_Condition(){
int i;
int sval = 0;
for (i = 0; i < 5; i++){
sval = sval + analogRead(0); // sensor on analog pin 0
sval = sval / 5; // average
sval = sval / 4; // scale to 8 bits (0 - 255)
sval = 255 - sval; // invert output
return sval;
What's the mathematical explanation to the lines:
Does it matter what range of voltage the sensor senses? it's not written
What's the explanation to the divison by 4?
Is there a site to learn?
Thanks
analogRead() delivers an integer between 0 and 1023. (10 bit)
Divide it by 4 to get an integer between 0 and 255. (8 bit)
Subtract the result from 255 to get an integer in the range 255 to 0. (Inverted)
KarolR:
KarolR:
the sensor range does matter for the above equation. 'analogRead(0)' is uses a 10bit ADC on most Arduinos (0-1023)
1024/256 = 4 <--- this is why it is dividing by 4 to scale to 8bits
hope that helps
ps 6v6gt beat me to it! :slight_smile:
KarolR:
1. Assume sval = 656 = 0x0290 = 0000 0010 1001 0000 = 1010010000 (10-bit active)
2. x = sval/4 = 164 = 0x00A4 = 10100100 (information in sval is not lost; sval is just compressed)
3. invert of x = not(x) = y = 01011011 = 0x5B = 91
4. y = 255 - sval = 255 - 164 = 91 (you got it).
The issue of concern is: analogRead(A0) has the range: 0 to 1023. We want to compress this value over the scale of 0 to 255; so, divide by 4 should be alright. It can be verified by the following map() function.
x (compressed value = sval/4) can also be obtained by using the following map() function:
byte z = map(x, 0, 1023, 0, 255);
Serial.print(z, HEX); //shows: A3 or A4 (163 or 164)
Or, you could just right shift sval by 2 (same as dividing by 4 with integers):
sval >>= 2;
KarolR:
If you are using an UNO, or Mega the voltage must NEVER exceed 5v or be negative (i.e. less than 0v).
...R
6v6gt:
What does it mean inverted?
If, for example, i measure 3v, the range is 0-5V (always?), does the function not(x) mean 5-3=2V?
Is the range always assumed 0-5V, not, for example, 0-3V? there are many kinds of sensors, though, no? probably not all return 0-5V, right?
KarolR:
Inverted in this context means that a high voltage on an analog pin is converted to a low value for a calculation.
Example for a 5 volt arduino (e.g. Uno )
5 volts on pin A0 would normally give an analog value of 1023 (the maximum which could be represented by a 10bit number)
3 volts on pin A0 would normally give an analog reading of 614.
2 volts on pin A0 would normally give an analog reading of 408.
However, you may want the result inverted. Say you had a light which should be bright during darkness and you measured the ambient light value with a photo cell. During darkness lets say the photocell causes a very low voltage on the analog input pin. You want to convert that low value to a high value to make the light bright (using PWM in this case).
If you took the 408 analog reading for 2 volts and inverted it you would get (with rounding errors) the analog reading for 3 volts.
The function not() does a logical inversion. That is it just changes true to false and false to true. It cannot operate on numbers.
A lot of sensors, say a light dependent resistor, are wired with a resistor across the arduino's power rails and divide the Arduino's voltage producing between say 0v and 5v on the analog pin depending on the light level.
A sensor which produced a maximum of 3 volts would show a maximum analog reading of 614 on an analog pin of a 5 volt arduino.
Depending on the application, it may be desirable to round the averaged result and/or the scaled result:
  uint16_t rawValue = 0;
  uint8_t scaledValue;
  for (uint8_t i = 0; i < 5; i++) {
    rawValue = rawValue + analogRead(0);    // sensor on analog pin 0
  rawValue = float(rawValue) / 5.0 + 0.5;    // average and round
  scaledValue = (rawValue + 0x02) >> 2;  // round and scale
  scaledValue = ~scaledValue; // invert
6v6gt:
For example:
byte z = map(656, 0, 1023, 0, 255);
  Serial.println(z, BIN);  //z = 10100011
  byte x1 = not(z);        //x1 = 0 = LOW; z is non-zero = HIGH
  byte x2 = ~z;
  Serial.println(x2, BIN); //x2 = bit wise inversion of Z = 1011100
sp.byte z = map(656, 0, 1024, 0, 256);
I think I'd take 8 samples instead of 5. Then, average, round, and scale all in one shot:
  for (uint8_t i = 0; i < 8; i++) {
  scaledValue = (rawValue + 0x10) >> 5;  // average, round, & scale
