hallo, i want to scan two barcode (8 digit and 10 digit) and then print to serial monitor.
first i scan a 8 digit barcode, then i scan a 10 digit barcode after that serial monitor display the numbers of 8 digit barcode and 10 digit barcode or first i scan a 10 digit barcode then i scan a 8 digit barcode after that serial monitor display the numbers of 10 digit barcode and 8 digit barcode.
and this is my code just scan 10 digit barcode
#include <hid.h>
#include <hiduniversal.h>
#include <usbhub.h>
#include <Usb.h>
#include <hidboot.h>
#include <avr/pgmspace.h>
const byte BarcodeLength = 11;
const byte WeightLength = 15;
const int buzzer = 2;
class BarcodeReader : public KeyboardReportParser
USB Usb;
USBHub Hub;
HIDUniversal Hid;
HIDBoot<HID_PROTOCOL_KEYBOARD> Keyboard;
uint8_t buffer[BarcodeLength + 1];
byte length;
bool valid;
void addCharacter(uint8_t c);
public:
BarcodeReader();
void begin();
void task();
const uint8_t* barcode();
void reset();
protected:
virtual void OnKeyDown(uint8_t mod, uint8_t key);
BarcodeReader::BarcodeReader()
: Usb()
, Hub(&Usb)
, Hid(&Usb)
, Keyboard(&Usb)
, length(0)
, valid(false)
void BarcodeReader::begin()
if (Usb.Init() == -1) {
Serial.println("OSC did not start.");
Hid.SetReportParser(1, this);
void BarcodeReader::task()
Usb.Task();
void BarcodeReader::addCharacter(uint8_t c)
if (valid) {
// already have a barcode, new one will overwrite it
reset();
// could check for \n or \r if necessary, or even implement a timing
// mechanism for detecting end of barcode input, but for now we just
// assume fixed width field with no output separators
buffer[length++] = c;
buffer[length] = '\0';
if (length == BarcodeLength) valid = true;
// return value no longer valid after another call to task()
const uint8_t* BarcodeReader::barcode()
return (valid) ? buffer : 0;
void BarcodeReader::reset()
length = 0;
valid = false;
void BarcodeReader::OnKeyDown(uint8_t mod, uint8_t key) {
uint8_t c = OemToAscii(mod, key);
if (c) addCharacter(c);
BarcodeReader barcodeReader;
pinMode(buzzer,OUTPUT);
barcodeReader.begin();
barcodeReader.task();
const char* barcode = barcodeReader.barcode();
if ( (barcode) {
Serial.println(barcode);
barcodeReader.reset();
weightReader.reset();
can you help me? thanks
Delta_G:
Gee, I wonder what variable in that code affects the length of the barcode it looks for.
i think it's for keep barcode data until 10 digit and then give the output 10 digit in serial monitor.
i try this code, and actually the code can scan any digit barcode but the output is not like what i want.
#include <hid.h>
#include <usbhub.h>
#include <Usb.h>
USB Usb;
USBHub Hub;
HIDUniversal Hid;
uint8_t buffer[15];
byte length;
bool valid;
public:
BarcodeReader();
void begin();
void task();
void reset();
protected:
: Usb()
, Hub(&Usb)
, Hid(&Usb)
, Keyboard(&Usb)
, length(0)
, valid(false)
Usb.Task();
if (valid) {
reset();
//buffer[length] = '\0';
if (buffer[length] == '\0')
valid = true;
length = 0;
valid = false;
Serial3.begin(9600);
if (barcode) {
if i scan barcode "10769876"
the output in serial monitor is:
1
0
7
6
9
8
7
6
if i scan barcode "0009285201"
0
0
0
9
2
8
5
2
0
1
if i scan barcode "KG"
K
G
I guess you want each barcode on one line? If so, replace Serial.printlln() by Serial.print() for starters.
Do you receive a carriage return or newline when you scan the barcode? If so, use that to go to a new line in the serial monitor (an empty Serial.println() will do that for you).
If you don't receive a carriage return or newline, you can implement a timeout on the receive. E.g. once no new data is received for e.g. 500ms, print an empty line using an empty Serial.println().
Try this it works for me..
#include <usbhid.h>
#include <usbhub.h>
#include <SPI.h>
class MyParser : public HIDReportParser {
public:
MyParser();
void Parse(USBHID *hid, bool is_rpt_id, uint8_t len, uint8_t *buf);
protected:
uint8_t KeyToAscii(bool upper, uint8_t mod, uint8_t key);
virtual void OnKeyScanned(bool upper, uint8_t mod, uint8_t key);
virtual void OnScanFinished();
MyParser::MyParser() {}
void MyParser::Parse(USBHID *hid, bool is_rpt_id, uint8_t len, uint8_t *buf) {
// If error or empty, return
if (buf[2] == 1 || buf[2] == 0) return;
for (uint8_t i = 7; i >= 2; i--) {
// If empty, skip
if (buf[i] == 0) continue;
// If enter signal emitted, scan finished
if (buf[i] == UHS_HID_BOOT_KEY_ENTER) {
OnScanFinished();
// If not, continue normally
else {
// If bit position not in 2, it's uppercase words
OnKeyScanned(i > 2, buf, buf[i]);
return;
uint8_t MyParser::KeyToAscii(bool upper, uint8_t mod, uint8_t key) {
// Letters
if (VALUE_WITHIN(key, 0x04, 0x1d)) {
if (upper) return (key - 4 + 'A');
else return (key - 4 + 'a');
// Numbers
else if (VALUE_WITHIN(key, 0x1e, 0x27)) {
return ((key == UHS_HID_BOOT_KEY_ZERO) ? '0' : key - 0x1e + '1');
return 0;
void MyParser::OnKeyScanned(bool upper, uint8_t mod, uint8_t key) {
uint8_t ascii = KeyToAscii(upper, mod, key);
Serial.print((char)ascii);
delay(1);
void MyParser::OnScanFinished() {
//Serial.println(" - Finished");
Serial.println(F("\r"));
USB Usb;
USBHub Hub(&Usb);
HIDUniversal Hid(&Usb);
MyParser Parser;
Serial.begin( 115200 );
//Serial.println("Start");
// Serial.println("OSC did not start.");
delay( 200 );
Hid.SetReportParser(0, &Parser);
Usb.Task();
I hope that OP did not wait a year for the solution
hi, can you provide me usb host shield barcode scanner code?
i have to further study on it
i am using mega 2560
jaden126:
Did you look at the codes and the advise that were given?
