How to scroll down/up a menu on a ST7920 128x64 LCD display ?
I'm working on developing a menu and I reached the part where I want to scroll down/up the menu but I don't know how.
This is the code I'm working on:
#include <U8g2lib.h>
// constants ////////////////////////////////////////////////
// # lists settings
#define   LIST_COUNT            8
#define   LIST_PER_FRAME        5
#define   LIST_Y_START_POINT    1
#define   LIST_X_START_POINT    2
#define   LIST_Y(_Y)            (LIST_Y_START_POINT+(12*_Y))
// # selection settings
#define   SELECT_WIDTH          65
#define   SELECT_HEIGHT         11
#define   SELECT_X_START_POINT  0
#define   SELECT_Y_START_POINT  0
#define   SELECT_Y(_Y)          (SELECT_Y_START_POINT+(12*_Y))
// variables ////////////////////////////////////////////////
uint8_t select_ptr = 0;
//uint8_t list_y = LIST_Y(0);
struct example_list{
  uint8_t y_position;
  const char* list_name;
example_list list1[] = {
  {LIST_Y(0), "SETTING 1"},
  {LIST_Y(1), "SETTING 2"},
  {LIST_Y(2), "SETTING 3"},
  {LIST_Y(3), "SETTING 4"},
  {LIST_Y(4), "SETTING 5"},
  {LIST_Y(5), "SETTING 6"},
  {LIST_Y(6), "SETTING 7"},
  {LIST_Y(7), "SETTING 8"},
U8G2_ST7920_128X64_1_HW_SPI u8g2(U8G2_R0, /* CS=*/ 10, /* reset=*/ 8);
void u8g2_prepare(void) {
  u8g2.setFont(u8g2_font_6x10_tf);
  u8g2.setFontRefHeightExtendedText();
  u8g2.setDrawColor(1);
  u8g2.setFontPosTop();
  u8g2.setFontDirection(0);
void glcd_initialize(void) {
  u8g2.begin();
  u8g2_prepare();
void glcd_print_list(void){
  u8g2.firstPage();
  do {
    // draw list
    for(int i = 0; i < LIST_COUNT; i++){
      u8g2.drawStr(LIST_X_START_POINT, list1[i].y_position, list1[i].list_name);
    // selected list
    u8g2.drawBox(SELECT_X_START_POINT, SELECT_Y(select_ptr), SELECT_WIDTH, SELECT_HEIGHT);
    u8g2.setDrawColor(0);
    u8g2.drawStr(LIST_X_START_POINT, list1[select_ptr].y_position, list1[select_ptr].list_name);
    if(select_ptr > 5){
      // u8g2.drawRFrame(u8g2,,,,); // <---------- I'm here
  } while (u8g2.nextPage());
As select_ptr will be modified by push button read function.
The u8g2 library has a graphics example with scrolling text.
Which example ?
I found this:
Introduction to U8log
U8log is an extension to U8g2 and U8x8. It implements a text window with automatic vertical scrolling. Text is written to the current cursor position within the text window.
at:
https://github.com/olikraus/u8g2/wiki/u8logreference#introduction-to-u8log
But how to find it ? I couldn't find it in the library folder.
OK found it in u8g2-master and not in u8glib-master.
OK, I ran the example but it's horizontal scroll. I want a vertical scroll.
Scroll fluidly, pixel by pixel?
Or swapping boxes? Like there's A, B, C. D in a column; you turn your knob and then they're B. C, D, E.
That would be, I think, a lot easier.
Or, similarly, you could have A, B, C, D and turning a knob changes which box is "active", with a border (highlight / outline).
Yep, after a lot of trail/error I did it this way:
// # lists settings
// # selection box settings
int8_t name_ptr = 0;
int8_t list_ptr = 0;
bool list_limi_lock = 0;
bool glcd_update = 0; // on button event, sensor read event ... etc.
"SETTING 1", "SETTING 2", "SETTING 3", "SETTING 4", "SETTING 5", "SETTING 6", "SETTING 7", "SETTING 8"
  u8g2.begin();
  u8g2_prepare();
  if(!button_lock && !glcd_update){
    u8g2.firstPage();
    do {
      u8g2.clearBuffer();
      // draw full list
      for(int i = 0, j = list_ptr; i < LIST_PER_FRAME; j++, i++){
        u8g2.drawStr(LIST_X_START_POINT, LIST_Y(i), list1[j].list_name);
      // draw selected list with selection box
      u8g2.drawStr(LIST_X_START_POINT, LIST_Y(select_ptr), list1[name_ptr].list_name);
      glcd_update = 1;
void glcd_update_button_control(void){
    if (lcd_button_index && button_execution == true) {
      switch(lcd_button_index){
        case BUTTON_UP:
          select_ptr--;
          name_ptr--;
          if(select_ptr < 0){ select_ptr = 0; list_ptr--; }
          if(name_ptr < 1){ name_ptr = 0;}
          if(list_ptr < 1){ list_ptr = 0;}
        case BUTTON_DOWN:
          select_ptr++;
          name_ptr++;
          if(select_ptr > 4){ select_ptr = 4; list_ptr++; }
          if(name_ptr > LIST_COUNT - 1){ name_ptr = LIST_COUNT - 1; }
          if(list_ptr > LIST_COUNT - LIST_PER_FRAME){ list_ptr = LIST_COUNT - LIST_PER_FRAME;}
        case BUTTON_SET:
        case BUTTON_BACK:
      lcd_button_index = NOT_SELECTED;
      button_execution = false;
      glcd_update = 0;
const char *convert_number(uint16_t number) {
  static char buf[3];
  strcpy(buf, u8g2_u8toa(number, 2));
  return buf;
const char *print_logic_state(bool number) {
  static char buf[3];
  strcpy(buf, u8g2_u8toa(number, 1));
  return buf;
const char *print_motor_speed(uint16_t number) {
  static char buf[3];
  strcpy(buf, u8g2_u8toa(number, 3));
  return buf;
I hope anyone find this helpful.
demo it on vimeo or youtube
Yep, I'm really planning to, just need some more time to finish my current projects.
