How to see if the Arduino M0 Pro is working?
Hey guys,
I have here an Arduino M0 Pro and I think it is not working. I already tried some projects with online tutorials, but none of them worked.
To give you an example, I tried the "blink example" that comes with arduino IDE, but nothing happened.
Here is the code:
// the setup function runs once when you press reset or power the board
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
  digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);                       // wait for a second
  digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
Plus, in the attachments you can see the arduino that I am using.
Is there another way to test it so that I can see if it works or not?
Thank you for your time,
Joao
