sorry PaulIs, now visual can recevive and know my char which i send from arduino, but i have some trouble with write data to rely arduino, can you help me again?
here is visual studio code:
#include <stdio.h>
#include <tchar.h>
#include "SerialClass.h"
#include <string>
#include <conio.h>
int readResult = 0;
char incomingData[3] = "";
int dataLength=3;
int _tmain(int argc, _TCHAR* argv[])
printf("Welcome to the serial test app!\n\n");
Serial* SP = new Serial("COM7");
if (SP->IsConnected())
printf("We're connected\n");
while(SP->IsConnected())
readResult = SP->ReadData(incomingData,dataLength);
incomingData[readResult] = 0;
printf("%s\n",incomingData);
if(!strcmp(incomingData,"<a>"))
printf("found a\n");
SP->WriteData("<b>",3);
Sleep(1000);
printf("not found a\n");
SP->WriteData("<c>",3);
Sleep(1000);
return 0;
and here is serial.cpp code:
include "stdafx.h"
Serial::Serial(char *portName)
//We're not yet connected
this->connected = false;
//Try to connect to the given port throuh CreateFile
this->hSerial = CreateFile(portName,
GENERIC_READ | GENERIC_WRITE,
0,
NULL,
OPEN_EXISTING,
FILE_ATTRIBUTE_NORMAL,
NULL);
//Check if the connection was successfull
if(this->hSerial==INVALID_HANDLE_VALUE)
//If not success full display an Error
if(GetLastError()==ERROR_FILE_NOT_FOUND){
//Print Error if neccessary
printf("ERROR: Handle was not attached. Reason: %s not available.\n", portName);
printf("ERROR!!!");
//If connected we try to set the comm parameters
DCB dcbSerialParams = {0};
//Try to get the current
if (!GetCommState(this->hSerial, &dcbSerialParams))
//If impossible, show an error
printf("failed to get current serial parameters!");
//Define serial connection parameters for the arduino board
dcbSerialParams.BaudRate=CBR_9600;
dcbSerialParams.ByteSize=8;
dcbSerialParams.StopBits=ONESTOPBIT;
dcbSerialParams.Parity=NOPARITY;
//Set the parameters and check for their proper application
if(!SetCommState(hSerial, &dcbSerialParams))
printf("ALERT: Could not set Serial Port parameters");
//If everything went fine we're connected
this->connected = true;
//We wait 2s as the arduino board will be reseting
Sleep(ARDUINO_WAIT_TIME);
Serial::~Serial()
//Check if we are connected before trying to disconnect
if(this->connected)
//We're no longer connected
//Close the serial handler
CloseHandle(this->hSerial);
int Serial::ReadData(char *buffer, unsigned int nbChar)
//Number of bytes we'll have read
DWORD bytesRead;
//Number of bytes we'll really ask to read
unsigned int toRead;
//Use the ClearCommError function to get status info on the Serial port
ClearCommError(this->hSerial, &this->errors, &this->status);
//Check if there is something to read
if(this->status.cbInQue>0)
//If there is we check if there is enough data to read the required number
//of characters, if not we'll read only the available characters to prevent
//locking of the application.
if(this->status.cbInQue>nbChar)
toRead = nbChar;
toRead = this->status.cbInQue;
//Try to read the require number of chars, and return the number of read bytes on success
if(ReadFile(this->hSerial, buffer, toRead, &bytesRead, NULL) && bytesRead != 0)
return bytesRead;
//If nothing has been read, or that an error was detected return -1
return -1;
bool Serial::WriteData(char *buffer, unsigned int nbChar)
DWORD bytesSend;
//Try to write the buffer on the Serial port
if(!WriteFile(this->hSerial, (void *)buffer, nbChar, &bytesSend, 0))
//In case it don't work get comm error and return false
return false;
return true;
bool Serial::IsConnected()
//Simply return the connection status
return this->connected;
