Hi, I'm trying to reuse the WiFiTelnetToSerial example code:
//check UART for data
if(Serial.available()){
size_t len = Serial.available();
uint8_t sbuf[len];
Serial.readBytes(sbuf, len);
//push UART data to all connected telnet clients
for(i = 0; i < MAX_SRV_CLIENTS; i++){
if (serverClients && serverClients*.connected()){*
_ serverClients*.write(sbuf, len);
delay(1);
}[/quote]
```_
char msg[10] = "123456789";
for (i = 0; i < 10; i++) {
if (serverClients[i] && serverClients[i].connected()) {
serverClients[i].write((const uint8_t ) msg, 10);
delay(1);
*_</em> <em>_*to send a string to a client, but I have errors, someone could tell me what my error is, my sketch*_</em> <em>_*is restarts continuously?*_</em> <em>_*Here is my error:*_</em> <em>_*> ESP ready*_</em> <em>_*> Server IP is : 192.168.4.1*_</em> <em>_*> Port is : 8888*_</em> <em>_*>*_</em> <em>_*> Exception (28):*_</em> <em>_*> epc1=0x40201280 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000038 depc=0x00000000*_</em> <em>_*>*_</em> <em>_*> >>>stack>>>*_</em> <em>_*Here is my complet code*_</em> <em>_*
*#include <ESP8266WiFi.h>
#include <EEPROM.h>
#include <WiFiClient.h>
#define SERIALBAUD 115200
#define MAXCLIENTS 4
//Access Point data
const char* ssid = "TES_ESP8266";
const char* password = "12345678";
const int LED_PIN = 2;
unsigned int localPort = 8888;
WiFiServer server(localPort);
//Server clients
WiFiClient serverClients[MAXCLIENTS];
pinMode(LED_PIN, OUTPUT);
digitalWrite(LED_PIN, HIGH);
EEPROM.begin(512);
Serial.begin(SERIALBAUD);
//Start Access Point
WiFi.disconnect(true);
WiFi.mode(WIFI_AP);
WiFi.softAP(ssid, password);
//Start Server
server.begin();
server.setNoDelay(true);
//Initialization finished
Serial.println(); Serial.println();
Serial.println("ESP ready");
Serial.print("Server IP is : "); Serial.println(WiFi.softAPIP());
Serial.print("Port is : ");
Serial.println(localPort);
uint8_t i;
if (server.hasClient()) { //check if there are any new clients
for (i = 0; i < MAXCLIENTS; i++) {
if (!serverClients[i] || !serverClients[i].connected()) { //find free/disconnected spot
if (serverClients[i])
serverClients[i].stop();
serverClients[i] = server.available();
//Serial.print("New client: "); Serial.print(i);
continue;
//no free/disconnected spot so reject
WiFiClient serverClient = server.available();
serverClient.stop();
//Serial.println("No client slot available");
//check clients for data
if (serverClients[i].available()) {
digitalWrite(LED_PIN, LOW);
//get data from the telnet client and push it to the UART
while (serverClients[i].available())
Serial.write(serverClients[i].read());
// //check UART for data
// if(Serial.available()) {
// digitalWrite(LED_PIN, LOW);
// size_t len = Serial.available();
// uint8_t sbuf[len];
// Serial.readBytes(sbuf, len);
// for(i = 0; i < MAXCLIENTS; i++) { //push UART data to all connected telnet clients
// if (serverClients[i] && serverClients[i].connected()) {
// serverClients[i].write(sbuf, len);
// delay(1);
delay(1);
