How to send a text file from my Arduino Nano to my phone
Hi there, I am trying to send a text file from my Arduino Nano to my phone using the Serial Bluetooth Terminal app. I know my circuit works as I have tried it with an alternative app but that would only send me data one bit at a time, whereas a text file is better for what I need it for
I have tried looking at a previous question related to this [here] but I am still having issues on my end
Here is my code, please ask if you have any more questions. Thank you
#include <SoftwareSerial.h>
#include <SPI.h>
//for SD card connection
#include <SD.h>
SoftwareSerial bluetooth(0, 1); // RX | TX
File root;
  bluetooth.begin(9600);
  Serial.println("SD text file sender starting");
  bluetooth.println("SD text file sender starting");
  if (!SD.begin(10))
    Serial.println("initialisation failed!");
    while (1);
  Serial.println("initialisation done.");
  //put text file you want to send here
  File dataFile = SD.open("test.TXT");
  // if the file is available, write to it:
  if (dataFile)
    while (dataFile.available())
      bluetooth.write(dataFile.read());
      //line below does not output on the app
      bluetooth.print("test line");
    dataFile.close();
what Nano are you using? I guess it is not a Nano 33 IoT with onboard BLE
what is the Bluetooth device?
I'm not sure on the exact Nano it is but I know it does not have BLE. The Bluetooth device I am using is the HC-05
The dumpfile example included in the SD section of the IDE should be all you need. Something like
This programme reads temperatures from  three DS18B20 sensors at one
second intervals for transmission over bluetooth - no timestamping
Every tenth reading is recorded on SD card in real numbers to two decimal
places. Each line is timestamped.
A new file is created at midnight using the date as the filename.
Daily files can be read from SD via bluetooth by sending MMDD
Credit to Hacktronics, Mellis & Igoe, Garage Box, Zoomkat, Bildr.org, etc.
Kudos to lar3ry in Saskatchewan, Stanley in KL, Coding Badly in Tx.
#include <OneWire.h>
#include <DallasTemperature.h>
#include "Wire.h"
#include <SD.h>
#include <SPI.h>
#define DS1307_ADDRESS 0x68
char filename[] = "00000000.CSV";
File myFile;
char dumpName[] = "00000000.CSV";
File dumpFile;
// Green group Dee Why (red or amber LED shields)
byte InThermo[8] =  {0x28, 0x69, 0xC2, 0xB0, 0x03, 0x00, 0x00, 0x9F };
byte OutThermo[8] = {0x28, 0x7A, 0x8B, 0xC0, 0x03, 0x00, 0x00, 0x2F};
byte DrainThermo[8] = {0x28, 0x54, 0xF7, 0x2D, 0x04, 0x00, 0x00, 0x68};
#define ONE_WIRE_BUS 3
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
byte  second, minute, hour, weekDay, day, month, year;
int k=0;
const int chipSelect = 4;
float tempC, InTemp, OutTemp, DrainTemp;
// Define the strings for our datastream IDs
char sensorId0[] = "InThermo";
char sensorId1[] = "OutThermo";
char sensorId2[] = "DrainThermo";
char charBuf [13];
String readString;
String StringOne;
  delay(300);//Wait for newly restarted system to stabilize
  pinMode(0, INPUT_PULLUP);   // just a precaution for bluetooth
  pinMode(53, OUTPUT);//MEGA use poin 10 if Uno
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect))
    Serial.println("Card failed");
    // don't do anything more:
    return;
  Serial.println("CARD OK");
      GetClock();
      getFileName();
   GetClock();
  if (today != day)
   today = day;
   getFileName();
   header();
   daily();
  if (thismonth !=month)
    thismonth=month;
    dailyheader();
    while (Serial.available())
    delay(3);
    char c = Serial.read();
    readString += c;
  }// end while
  if (readString.length() >0)
    getDump();
   readString="";
  } // end if
  //get the values from the DS8B20's
  sensors.requestTemperatures();
  InTemp = sensorValue(InThermo);
  OutTemp = sensorValue(OutThermo);
  DrainTemp = sensorValue(DrainThermo);
  k=k+1;
  if (k>9 )
  myFile.print(hour);
  myFile.print(":");
  myFile.print(minute);
  myFile.print(":");
  myFile.print(second);
  myFile.print(",");
  myFile.print(InTemp);
  myFile.print(",");
  myFile.print(OutTemp);
  myFile.print(",");
  myFile.println(DrainTemp);
  k=0;
}  // loop ends here
//sensorValue function
float sensorValue (byte deviceAddress[])
  tempC = sensors.getTempC (deviceAddress);
  return tempC;
void getFileName()
myFile.close();//>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>CLOSE
sprintf(filename, "%02d%02d%02d.csv", year, month, day);
myFile = SD.open(filename, FILE_WRITE);//<<<<<<<<<<<<< OPEN
void GetClock() {
  // Reset the register pointer
  Wire.beginTransmission(DS1307_ADDRESS);
  byte zero = 0x00;
  Wire.write(zero);
  Wire.endTransmission();
  Wire.requestFrom(DS1307_ADDRESS, 7);
  second = bcdToDec(Wire.read());
  minute = bcdToDec(Wire.read());
  hour = bcdToDec(Wire.read() & 0b111111); //24 hour time
  weekDay = bcdToDec(Wire.read()); //0-6 -> sunday - Saturday
  day = bcdToDec(Wire.read());
  month = bcdToDec(Wire.read());
  year = bcdToDec(Wire.read());
byte bcdToDec(byte val)  {
  // Convert binary coded decimal to normal decimal
  return ( (val/16*10) + (val%16) );
void getDump() {
   StringOne = "2020" + readString + ".csv";
   StringOne.toCharArray(charBuf, 13);
     Serial.println("");
     Serial.println(charBuf);
  File dumpFile = SD.open(charBuf);
  if (dumpFile)
    while (dumpFile.available())
      Serial.write(dumpFile.read());
    dumpFile.close();
  else {
    Serial.println("error opening file");
Should be reasonably self-explanatory. Strip out what you don't need.
