How to send a variable by SMS using SIM800L Module
Hi guys,
I am trying to make an Energy Monitor with the consult of the values measured by GPRS.
I have developed the code below so far:
#include <Sim800l.h>
#include <SoftwareSerial.h> //is necesary for the library!!
Sim800l Sim800l;  //to declare the library
char* text;
char* number;
bool error; //to catch the response of sendSms
int fatura=200;
String textSms, numberSms;
uint8_t index1;
uint8_t LED2 = 13; // use what you need
  pinMode(LED2, OUTPUT);
  digitalWrite(LED2, HIGH);
  Serial.begin(9600); // only for debug the results .
  Sim800l.begin(); // initializate the library.
  Sim800l.reset();
  //don't forget to catch the return of the function delAllSms!
  error = Sim800l.delAllSms(); //clean memory of sms;
  textSms = Sim800l.readSms(1); //read the first sms
  if (textSms.indexOf("OK") != -1) //first we need to know if the messege is correct. NOT an ERROR
    if (textSms.length() > 7)  // optional you can avoid SMS empty
      numberSms = Sim800l.getNumberSms(1); // Here you have the number
      //for debugin
      Serial.println(numberSms);
      textSms.toUpperCase();  // set all char to mayus ;)
      if (textSms.indexOf("Value") != -1) {
        text = "fatura"; //text for the message.
        number = "2926451386"; //change to a valid number.
        error = Sim800l.sendSms(number, text);
      else {
        Serial.println("Not Compatible ...sorry.. :D");
      Sim800l.delAllSms(); //do only if the message is not empty,in other case is not necesary
      //delete all sms..so when receive a new sms always will be in first position
What I want to do is receive the value regarding the variable fatura declared in the top when I send a message to Arduino written "Value" from my mobile phone.
I think with this code programmed like the posted code, I will receive a message written "fatura". I dont want it. I want receive a message with the number 200, which is the value of the variable "fatura".
Does anybody can help me?
Replace
With
char text[10];
sprintf(text,"%d", fatura);  // or itoa(fatura, text, 10 );
Thus way you build a string with the fatura value in ASCII
#include<SoftwareSerial.h>
#include <Wire.h>
#include "SIM900.h"
#include "sms.h"
#define SIM800_TX_PIN 2
#define SIM800_RX_PIN 3
SMSGSM sms;
SoftwareSerial serialSIM800(SIM800_TX_PIN,SIM800_RX_PIN);
LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
int sensorPin = A0;
int sensor = A1;
int sensorValue = 0;
float volts=0.0;
float temp=0.0;
float tempF=0.0;
int led = 9;
int buzzer = 12;
pinMode(led, OUTPUT);
pinMode(buzzer,OUTPUT);
serialSIM800.begin(9600);
lcd.begin(16,2);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Fire Scanner ON!");
Serial.println("Fire Alarm System Using Arduino Uno With SMS notification");
sensorValue = analogRead(sensorPin);
sensor = analogRead(A1);
float volts = (sensor/1024.0)5.0;
float temp = volts
100.0;
float tempF = temp*9/5+32;
Serial.print("temperature= ");
Serial.println(temp);
Serial.println(sensorValue);
if (sensorValue < 500)
if (gsm.begin(2400))
lcd.clear();
lcd.print("Sunog Sunog!!");
Serial.println("Fire Detected");
Serial.println("in the Kitchen!");
digitalWrite(led,HIGH);
digitalWrite(buzzer,HIGH);
delay(200);
digitalWrite(led,LOW);
digitalWrite(buzzer,LOW);
delay(sensorValue);
if (sms.SendSMS("+639169441596", "Fire Detected in the kitchen"));
hi can you pls help me im a beginner in arduino and im struggling to this continuously sending an alert message to the number i put inside the code your help will be great thank you :slight_smile:
Please use code tags
Forget the sms for the time being. Get rid also if the lcd. You’ll add those in later
Can you write a code that monitors your sensors and print an alert message to the serial console when the fire is detected ?
Decide also what needs to happen once the message has been printed - I’ve not seen any requirements there
