How to send analog value from xbee to excel file
Hello there, I am trying to send data from my arduino to another and import data to an excel file. I am using a temperature and humidity sensor DHT11. can you help in providing the code.
below the code I have but it imports data to a program called X-CTU
#define DHT11_PIN 0 // ADC0
byte read_dht11_dat()
byte i = 0;
byte result=0;
for(i=0; i< 8; i++){
while(!(PINC & _BV(DHT11_PIN))); // wait for 50us
delayMicroseconds(30);
if(PINC & _BV(DHT11_PIN))
result |=(1<<(7-i));
while((PINC & _BV(DHT11_PIN))); // wait '1' finish
return result;
DDRC |= _BV(DHT11_PIN);
PORTC |= _BV(DHT11_PIN);
Serial.println("Ready");
byte dht11_dat[5];
byte dht11_in;
byte i;
// start condition
// 1. pull-down i/o pin from 18ms
PORTC &= ~_BV(DHT11_PIN);
delay(18);
delayMicroseconds(40);
DDRC &= ~_BV(DHT11_PIN);
dht11_in = PINC & _BV(DHT11_PIN);
if(dht11_in){
Serial.println("dht11 start condition 1 not met");
return;
delayMicroseconds(80);
if(!dht11_in){
Serial.println("dht11 start condition 2 not met");
return;
// now ready for data reception
for (i=0; i<5; i++)
dht11_dat = read_dht11_dat();
  • DDRC |= _BV(DHT11_PIN);*
  • PORTC |= _BV(DHT11_PIN);*
  • byte dht11_check_sum = dht11_dat[0]+dht11_dat[1]+dht11_dat[2]+dht11_dat[3];*
  • // check check_sum*
  • if(dht11_dat[4]!= dht11_check_sum)*
  • Serial.println("DHT11 checksum error");*
  • Serial.print("Current humdity = ");*
  • Serial.print(dht11_dat[0], DEC);*
  • Serial.print(".");*
  • Serial.print(dht11_dat[1], DEC);*
  • Serial.print("% ");*
  • Serial.print("temperature = ");*
  • Serial.print(dht11_dat[2], DEC);*
  • Serial.print(dht11_dat[3], DEC);*
  • Serial.println("C ");*
  • delay(2000);*
what abouth get all data from sensor to sd card ;). this is great tutorial and there is used excel: Tutorial 11 for Arduino: SD Cards and Datalogging - YouTube
You can use a python script to listen to the serial port and save the data into a text document. Excel can import files in .csv and .txt (with tab as a field separator). you can view more information on excel importing at http://office.microsoft.com/en-us/excel-help/import-or-export-text-txt-or-csv-files-HP010099725.aspx
http://apexlogic.net/code-bank/python/pyserial-example/
here is a an example to read information from the arduino through a python script.
