Hello All,
Now I am working on to interface ESP8266(total 8 pin 2 gpio) with my UNO.
I had three questions.
1st
How to send and receive AT commands ?. using software serial. Automatically in Arduino sketch ?
2nd
can I use this software serial baud rate is 115200 ?. not recommend then How to change the esp baud rate permanently ?.
I tried this IPR=9600. it is working. but next time I got garbage value.(after power off and on or reset)
And I tried AT+CIOBAUD=9600. But I got error.
I am using update the esp module firmware using esp8266_flasher.exe and firmware is v0.9.5.2AT Firmware.bin
I am connected first with my CP2102 USB to TTL
And manually feed the AT commands I got response (I have attached the response screen shot)
like this
AT+GMR
AT version:0.21.0.0
SDK version:0.9.5
3rd
I got my esp module hot some times.
(on that time the red led glow very dim. that time the module very hot)
I read some web sites. make 5volt logic level to 3.3volt logic level So I used two resistor in (voltage divider) in arduino tx pin. Still I got my chip very hot. That time I noticed the power red led glow very fading.
I changed the power supply.
Noticed
in CP2102 I did not used voltage divider but I got module response. Some times I got module heat.
I am using 3.3volt regulator and 2amp power adapter for module supply.
I read some sites old version did not set the baud rate permanently but the new firmware support permanent baud rate. That is why I trying to change the baud rate.
I have attached 2 files.
1.The response screen shot.
2.Connections
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2,3); //RX,TX
void setup(){
mySerial.begin(115200);
mySerial.println("AT");
delay(100);
long b=mySerial.read();
Serial.write(b);
delay(100);
b="";
mySerial.println("AT+CIPMUX=1");
b=mySerial.read();
Serial.write(b);
delay(100);
b="";
mySerial.println("AT+CIPSERVER=1,80");
b=mySerial.read();
Serial.write(b);
delay(100);
b="";
mySerial.println("AT+CIFSR");
b=mySerial.read();
Serial.write(b);
delay(100);
b="";
void loop(){
if(Serial.available()>0){
byte b=Serial.read();
mySerial.write(b);
if(mySerial.available()>0){
byte b=mySerial.read();
Serial.write(b);
