How to send and recieve data via 433MHZ module
i just purchased 433MHZ Serial communication module Transmitter and Receiver to control remote robot via PC keyboard. Transmitter part is connected to PC via TTL converter, and Receiver part is connected to remote Arduino Uno kit. i need to open LED which built in Arduino on Pin 13 when pressed 'P' and turn it off when pressed 'F'
433MHZ module contain 5 pins VCC GND RX TX SET
i need sketch of this process
thank you :)
Do you have a link to your transmitter/receiver?
http://store.fut-electronics.com/11WRL-003.html
The answer to your question is in your link. Its a basic serial connection of which, you can use software serial.
Look at the PDF. http://www.fut-electronics.com/wp-content/plugins/fe_downloads/Uploads/Wireless-Serial-UART-Arduino.pdf
where is the Transmitter Code and Receiver Code ?
Its in the PDF at the bottom.
This is literally all you need, it does both transmit and receive. It couldn’t be any simpler.
Bottom of PDF
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
Serial.begin(57600);
Serial.println(“Goodnight moon!”);
// set the data rate for the SoftwareSerial port
//Future Electronics Egypt Ltd. (Arduino Egypt).
mySerial.begin(4800);
mySerial.println(“Hello, world?”);
void loop() // run over and over
if (mySerial.available())
Serial.write(mySerial.read());
if (Serial.available())
mySerial.write(Serial.read());
