How to send and recieve multi value communication with 2 HC-05
MASTER
#define SENSOR 2 // define pint 2 for sensor
#define ACTION 9 // define pin 9 as for ACTION
#include <Wire.h>
#include <SoftwareSerial.h>
SoftwareSerial BTserial(10, 11);
LiquidCrystal_I2C lcd(0x27,20, 4);
float value=0;
float rev=0;
int rpm;
int spd;
int oldtime=0;
int time;
int Count = 0;
int Sensor_value =digitalRead(SENSOR);
int mnt;
int mntm;
void isr() //interrupt service routine
rev++;
void cnt() //count
 Count++;
 digitalWrite(6,HIGH);
 delay(100);
 pinMode(SENSOR, INPUT_PULLUP);
 pinMode(ACTION, OUTPUT);
 attachInterrupt(0,isr,RISING);  //attaching the interrupt
 attachInterrupt(1,cnt,FALLING);  //attaching the interrupt
 lcd.begin();
 lcd.setCursor(4,0 );
 lcd.print("LCD Display");
 lcd.setCursor(4,2 );
 lcd.print("Welcome :D");
 delay(3000);
 lcd.clear();
 BTserial.begin(38400);
mnt++;
//------------------------------------------ SPEED
detachInterrupt(0);           //detaches the interrupt
time=millis()-oldtime;        //finds the time
rpm=(rev/time)*60000;         //calculates rpm
spd=(rpm*0.10472*0.508);         //calculate speed
oldtime=millis();             //saves the current time
rev=0;
int sspd=spd/2;
int ccnt=Count/2;
int ttm=mnt/60;
lcd.clear();
lcd.setCursor(0,0);
lcd.print("SPEED");
lcd.setCursor(10,0);
lcd.print(     sspd);
lcd.print("   Km/Hr");
//------------------------------------------ ROUND
lcd.setCursor(0,1);
lcd.print("COUNT");
lcd.setCursor(10,1);
lcd.print(ccnt);
lcd.print("   Rounds");
//-------------------------------------------- TIME
lcd.setCursor(0,2);
lcd.print("TIME");
lcd.setCursor(10,2);
lcd.print(    ttm);
lcd.print("   Min");
//-------------------------------------------- CALORIES BURN
lcd.setCursor(0,3);
lcd.print("CALORIES");
lcd.setCursor(10,3);
lcd.print("X");
lcd.print("   KCAL");
BTserial.print(sspd);
BTserial.print(ccnt);
BTserial.print(ttm);
delay(100);
SLAVE
#include <Wire.h>
#include <Adafruit_SH1106.h>
#include <Adafruit_GFX.h>
// OLED display TWI address
#define OLED_ADDR   0x3C
int state = 0;
String strReceived = "";
int speeda=0;
Adafruit_SH1106 display(-1);
#if (SSD1306_LCDHEIGHT != 64)
#endif
 // initialize and clear display
 display.begin(SH1106_SWITCHCAPVCC, OLED_ADDR);
 display.clearDisplay();
 display.setTextSize(1.5);
 display.setTextColor(WHITE);
 display.setCursor(20,30);
 display.println("Welcome :D");
 display.display();
 delay(3000);
 // display a line of text
  if (BTserial.available() > 0) // Checks whether data is comming from the serial port
speeda = BTserial.read(); // Reads the data from the serial port
display.setTextSize(1);
 display.setCursor(0,1);
 display.print("SPEED");
 display.setCursor(70,1);
 display.print(speeda);
 display.setCursor(100,1);
 display.print("KM/H");
 display.setCursor(0,10);
 display.print("CALORIES");
 display.setCursor(100,10);
 display.print("KCAL");
 display.setCursor(0,20);
 display.print("DISTANCE");
 display.setCursor(100,20);
 display.print("M");
 display.setCursor(0,30);
 display.print("TIME");
 display.setCursor(100,30);
 display.print("MIN");
 // update display with all of the above graphics
 display.display();
I don’t know how to send and recive this data help me please. :confused: :confused:
You need to design / implement a protocol. Based on Serial Input Basics, you can send something like
BTserial.print("<");
BTserial.print(",");
BTserial.print(">");
Next you can use example #5 for the receiving end; the Serial in the reading part of the example needs to be changed to BTserial.
Please read How to use this forum, specifically point #7 about posting code.
Thank you for help sterretje ;)
I try to write code like this. But the displayed value does not change. It’s 0. What am I doing wrong?
SLAVE
#include <Wire.h>
//values-----------------------
int speeda = 0.0;
int counta = 0.0;
int timea = 0.0;
//receiving data---------------
const byte numChars = 64;
char receivedChars[numChars];
boolean newData = false;
char tempChars[numChars];
#endif
 display.setTextSize(2);
 display.println("Welcome!");
 display.display();
void recvWithStartEndMarkers() {
 static boolean recvInProgress = false;
   static byte ndx = 0;
   char startMarker = '<';
   char endMarker = '>';
   char rc;
while (BTserial.available() > 0 && newData == false) {
       rc = BTserial.read();
       if (recvInProgress == true) {
           if (rc != endMarker) {
               receivedChars[ndx] = rc;
               ndx++;
               if (ndx >= numChars) {
                   ndx = numChars - 1;
           else {
               receivedChars[ndx] = '\0'; // terminate the string
               ndx = 0;
               newData = true;
       else if (rc == startMarker) {
           recvInProgress = true;
void parseData() {      // split the data into its parts
   char * strtokIndx; // this is used by strtok() as an index
   strtokIndx = strtok(NULL, ","); // this continues where the previous call left off
   speeda = atoi(strtokIndx);     // convert this part to an integer
   counta = atoi(strtokIndx);     // convert this part to a float
   timea = atoi(strtokIndx);     // convert this part to a float
void showParsedData() {
 display.setCursor(70,20);
 display.print(counta);
 display.print("M");
 display.setCursor(70,30);
 display.print(timea);
 display.display();
      recvWithStartEndMarkers();
   if (newData == true) {
       strcpy(tempChars, receivedChars);
           // this temporary copy is necessary to protect the original data
           //   because strtok() used in parseData() replaces the commas with \0
       parseData();
       showParsedData();
       newData = false;
Start by adding some debug print statements; e.g. in loop
    [color=red]Serial.print("Received: ");
    Serial.println(receivedChars);[/color]
    parseData();
    showParsedData();
    newData = false;
The first time that you call strtok() to start parsing, the first argument should not be NULL but tempChars.
  [color=red][s]strtokIndx = strtok(NULL, ","); // this continues where the previous call left off[/s][/color]
  [color=green]strtokIndx = strtok(tempChars, ","); // this continues where the previous call left off[/color]
Please fix your comments; atoi does not convert to float.
