How to send data from arduino to database (Mysql-PHP-Arduino)
Hi All
i have a project and using PIR sensor
i want to make arduino can send data of PIR sensor status to my database
the values of data are “MOVEMENT” and “NO MOVEMENT”
i have 2 file for this project
connec.php and ardu.php
connec.php
<?php
function Connection(){
   if (!($link=mysql_connect("localhost","root","")))  {
      exit();
   if (!mysql_select_db("arduino",$link)){
      exit();
   return $link;
ardu.php
<?php
   include("connec.php");
   $link=Connection();
   if(isset($_GET['stpump1'])) {
     $statp1=$_GET['stpump1'];
     echo ("status=$statp1 \r\n" );
         echo "\r\n";
    $Sql="insert into 'tblevel' ('stpump1')  values ('".$statp1."')";
     mysql_query($Sql,$link);
    else {
          $result=mysql_query("select * from tblevel order by id desc",$link);
sensorpir.ino
#include <Ethernet.h>
#include <SPI.h>
#include <Client.h>
byte mac[]         = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // Mac Address Default
  IPAddress ip(192, 168, 0, 99);
  IPAddress subnet(255, 255, 255, 0);
  // change to your server
  IPAddress server(192,168,0,111);
  //Change to your domain name for virtual servers
  char serverName[] = "192.168.0.111";//"http://localhost/";
String data;
int PIR = 2;          // PIR sensor is connected to digital pin 2
int PIRstate = 0;     // variable for PIR sensor status
int serverPort = 80;
EthernetClient client;
char buffer [256];
char c1[13];
char* cp[]={"statuspir="};
char* cs[]={"NO MOVEMENT","MOVEMENT"};
char pageAdd [128];
#define delayMillis 30000UL
  unsigned long thisMillis = 0;
  unsigned long lastMillis = 0;
void setup(void)
  pinMode(PIR, INPUT);
     Ethernet.begin(mac, ip, subnet);
    digitalWrite(10,HIGH);
    Serial.println(Ethernet.localIP());
    delay(2000);
    Serial.println(F("Ready"));
void loop(void) {
  thisMillis = millis();
    if(thisMillis - lastMillis > delayMillis)
      lastMillis = thisMillis;
PIRstate = digitalRead(2);
          if (PIRstate==0){
        strcpy (c1, cp[0]); //pir sensor
        strcat (c1, cs[0]);  //NO MOVEMENT
        strcpy (c1, cp[0]);
      strcat (c1, cs[1]);
      sprintf(pageAdd,"/ardu.php?status=%s",c1);
      if(!getPage(server,serverPort,pageAdd)) Serial.print(F("Fail "));
      else Serial.print(F("Pass "));
      Serial.println(c1);
      Serial.println(pageAdd);
byte getPage(IPAddress ipBuf,int thisPort, char *page)
    int inChar;
    char outBuf[128];
    Serial.print(F("connecting..."));
    if(client.connect(ipBuf,thisPort))
      Serial.println(F("connected"));
      sprintf(outBuf,"GET %s HTTP/1.1",page);
      client.println(outBuf);
      sprintf(outBuf,"Host: %s",serverName);
      client.println(F("Connection: close\r\n"));
      Serial.println(F("failed"));
      return 0;
    // connectLoop controls the hardware fail timeout
    int connectLoop = 0;
    while(client.connected())
      while(client.available())
        inChar = client.read();
        Serial.write(inChar);
        // set connectLoop to zero if a packet arrives
        connectLoop = 0;
      connectLoop++;
      // if more than 10000 milliseconds since the last packet
      if(connectLoop > 10000)
        // then close the connection from this end.
        Serial.println(F("Timeout"));
        client.stop();
      // this is a delay for the connectLoop timing
      delay(1);
    Serial.println(F("disconnecting."));
    // close client end
    client.stop();
    return 1;}
database
ardu.php
the problem is,how to send and insert data of the sensor status to my databases because my database still empty when i upload the program and move a sensor(to change PIRstate values)
and ardu.php not shown an error but it still clear and not show the values of c1
Sorry about my english
i hope anyone can help me
thank you all :slight_smile:
You have a problem on the php end. The Arduino is sending a variable "status", and the php code is looking for "stpump1". These variable names must match.
Thanks for your response SurferTim :slight_smile:
i have changed my code and make it same
ardu.php
<?php
   $link=Connection();
     echo ("stpump1=$statp1 \r\n" );
         echo "\r\n";
    else {
sensor.ino
#include <SPI.h>
#include <Client.h>
String data;
char buffer [256];
char c1[13];
char* cp[]={"stpump1="};
char* cs[]={"NO MOVEMENT","MOVEMENT};
char pageAdd [128];
void setup(void)
    delay(2000);
void loop(void) {
          if (PIRstate==0){
        strcpy (c1, cp[0]); //pump1
        strcat (c1, cs[0]);  //status ON
        strcpy (c1, cp[0]);
      strcat (c1, cs[1]);
      sprintf(pageAdd,"/ardu.php?stpump1=%s",c1);
      Serial.println(c1);
    int inChar;
    char outBuf[128];
      return 0;
        connectLoop = 0;
      connectLoop++;
        client.stop();
      delay(1);
    // close client end
    client.stop();
    return 1;}
But my database still empty like before :frowning:
What does the serial monitor show? If not enough, add some debug stuff.
cp[0] is "stpump1=" cs[0] is "NO MOVEMENT"
How can you reasonably expect all that, and a terminating NULL to fit in:
char c1[13];
hello can i ask? what if im using mq135 gas sensor to send data to database, is it have a source code or reference? thank you so much
