HI TO ALL AND THE COMMUNITY OF ARDUINO AND THE WORLD OF CODING!!
Can I request for help or any guidance that can be useful to my MP Coding
i been trying to code for the arduino uno wifi rev 2 and ultrasonic to thingspeak but i could not get it work and same for if i use arduino nano 33 IoT board !
If anyone is willing to help and give me a guidance or a code to run that will be helpful
P.S. :
I AM NOT USING ESP8266 , IM USING A BULIT-IN WIFI ARDUINO BOARD Which is WiFiNINA and thingspeak
so do help as it is urgent and i praay to god some one will help
/////////// testing wifi to cloud and dat to cloud /////////////////////////
#include <SPI.h>
#include <WiFiNINA.h>
#include <ThingSpeak.h>
//setup wifi system
char ssid[] = "xxxxxxxxx"; // your network SSID (name) between the " "
char pass[] = "xxxxxxxxxx"; // your network password between the " "
int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS; //connection status
WiFiServer server(80); //server socket
WiFiClient client = server.available();
//define pin and data and component part info
#define echoPin 2 // attach pin D2 Arduino to pin Echo of HC-SR04
#define trigPin 3 //attach pin D3 Arduino to pin Trig of HC-SR04
//read the val and data
long Duration; // variable for the duration of sound wave travel
int Distance; // variable for the distance measurement
// ThingSpeak Settings
char thingSpeakAddress[] = "api.thingspeak.com";
char mychannelID[] = " xxxxxxxx";
String APIKey = "xxxxxxxxxxxxxxxx"; // enter your channel's Write API Key
unsigned long lastConnectionTime = 0; // Track the last connection time
unsigned long lastUpdateTime = 0; // Track the last update time
const unsigned long postingInterval = 20L * 1000L; // Post data every 2 minutes
const unsigned long updateInterval = 15L * 1000L; // Update once every 15 seconds
Serial.begin(9600); // // Serial Communication is starting with 9600 of baudrate speed
Serial.println("MP PROJECT 2022 TESTING"); // print some text in Serial Monitor
Serial.println("with Arduino UNO WiFi Rev2");
// Attempt to connect to WiFi network
while (WiFi.status() != WL_CONNECTED)
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
WiFi.begin(ssid, pass); // Connect to WPA/WPA2 network. Change this line if using open or WEP network
delay(10000); // Wait 10 seconds to connect
// you're connected now, so print out the status:
Serial.println("WiFi Connected Successfully");
printWifiStatus(); //Print WiFi connection information
//////// Configuration of pinMode for ultrasonic sensor ////////
pinMode(trigPin, OUTPUT); // Sets the trigPin as an OUTPUT
pinMode(echoPin, INPUT); // Sets the echoPin as an INPUT
//end "setup()"
//Start of Program - DISTANCE FALL PROGRAM
// Clears the trigPin condition
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
// Sets the trigPin HIGH (ACTIVE) for 10 microseconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
Duration = pulseIn(echoPin, HIGH);
// Calculating the distance
Distance = Duration * 0.034 / 2; // Speed of sound wave divided by 2 (go and back)
// Displays the distance on the Serial Monitor
Serial.print("Distance: ");
Serial.print(Distance);
Serial.println(" cm");
//thingspeak and cloud upload settings and coding
if (millis() - lastUpdateTime >= updateInterval)
String distance = String(Distance);
updateThingSpeak("field1= 12" + distance);
lastUpdateTime = millis(); // Update last update time
//end loop()
void updateThingSpeak(String tsData)
if (client.connect(thingSpeakAddress, 80))
client.println("POST /update HTTP/1.1\n");
client.println("Host: api.thingspeak.com\n");
client.println("Connection: close\n");
client.println("X-THINGSPEAKAPIKEY: " + APIKey + "\n");
client.println("Content-Type: application/x-www-form-urlencoded\n");
client.print("Content-Length: ");
client.println(tsData.length());
client.println("\n\n");
client.println(tsData);
if (client.connected())
Serial.println("Connecting to ThingSpeak...");
void printWifiStatus()
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
the wserial monitor is all working
my ultrasonic is displaying data on serial monitor but not on thingspeak unless i change the field code to a fix number then it will update to the nummber according per hour
That suggests there is something wrong with the number …
And that’s where to look hard .
If you can upload a number - I presume that number is an integer or maybe a float . You need to do some work in that area , eg …
Is “ long ” different on a nano IOT compared to a uno ? ( no idea ) , load fixed numbers into the code , see which work .
What is the number format in the examples with the library ?
Have a look on the thingspeak page / forum .
Nano IOT has reserved pins for some of the on board stuff - check again for conflicts ( although you say you can upload fixed numbers )
Look carefully ( again ) at the library examples and work from those
I gave no idea if thingspeak , but that’s how I would start to tackle it.
