Hi Team,
unsigned char buf[100] = {0};
unsigned char len = 0;
float value = 1.117;
len = sprintf(buff, “%d”, value);
ble_write_bytes(buff, len);
Expected output: 1.117
Actual output = 1
How to get 1.117 as output?
Hi Team,
Actual output = 1
The normal Arduino IDE does not support the use of floats in sprintf()
In any case, is %d the format specifier for a float ?
One way is to use the dtostrf() function to convert the float to a string and use %s parameter in the sprintf().
The snprintf() function is safer to use as it protects from inadvertent buffer overruns.
groundFungus:
One way is to use the dtostrf() function to convert the float to a string and use %s parameter in the sprintf().The snprintf() function is safer to use as it protects from inadvertent buffer overruns.
Hi groundFungus,
Thanks, It's working.
dtostrf(value, 4, 4, strA); //dtostrf(floatvar, StringLengthIncDecimalPoint, numVarsAfterDecimal, charbuf);
ble_write_bytes((unsigned char *)strA, strlen(strA) + 1);
