Would like to automate some servo motors for pulling blinds using ethernet. Where should I start?
Search for "arduino web blink" as a starting point. Once you understand how to blink a LED via web commands you can expand your program to operate servo motors or whatever you want.
Spent all day reading and learning about this... Found an example and modified a few things to fit my situation and here's what I've gotten. However, whenever I click on the tabs on the web it doesn't do anything for me. Also the interface is extremely slow and hangs all the time.
I do have an SDcard reader so perhaps if I can iron this out I can start learning about how to host my own server on the SD card.
Created by Rui Santos
Visit: http://randomnerdtutorials.com for more arduino projects
Arduino with Ethernet Shield
#include <SPI.h>
#include <Ethernet.h>
#include <Servo.h>
Servo microservo;
int pos = 0;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 178 }; // ip in lan (that's what you need to use in your browser. ("192.168.1.178")
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(80); //server port
String readString;
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
microservo.attach(9);
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip, gateway, subnet);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
// Create a client connection
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString); //print to serial monitor for debuging
client.println("HTTP/1.1 200 OK"); //send new page
client.println("Content-Type: text/html");
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<meta name='apple-mobile-web-app-capable' content='yes' />");
client.println("<meta name='apple-mobile-web-app-status-bar-style' content='black-translucent' />");
client.println("<link rel='stylesheet' type='text/css' href='http://randomnerdtutorials.com/ethernetcss.css' />");
client.println("<TITLE>Random Nerd Tutorials Project</TITLE>");
client.println("</HEAD>");
client.println("<BODY>");
client.println("<H1>Living Room Blinds Control</H1>");
client.println("<hr />");
client.println("
client.println("<H2>Arduino with Ethernet Shield</H2>");
client.println("
client.println("
client.println("<a href=\"/?button2on\"\">Rotate Left</a>");
client.println("<a href=\"/?button2off\"\">Rotate Right</a>
client.println("</BODY>");
client.println("</HTML>");
delay(1);
//stopping client
client.stop();
//controls the Arduino if you press the buttons
if (readString.indexOf("?button2on") >0){
microservo.attach(9); // attaches the servo on pin 9 to the servo object
microservo.write(180); // sets the servo position according to the scaled value
delay(1150); // waits for it to get to the position
microservo.detach();
delay(1000); }
if (readString.indexOf("?button2off") >0){
microservo.write(0); // sets the servo position according to the scaled value
}} // waits 15ms for the servo to reach the position
Please re-format your code (Tools->Auto Format) and post it between code tags </> so it is readable (edit the existing post).
It looks to me that you havent matched the opening and closing braces at the right places- autoformating will show if this is the case
The below may be the source of your slowdown.
zoomkat:
The below may be the source of your slowdown.client.println("<link rel='stylesheet' type='text/css' href='http://randomnerdtutorials.com/ethernetcss.css' />");
Do you think that the server on that end is the slow down? It's the only example that I could find closest to what I want to do without reinventing it. Is the code to use the similar commands/format to host the page on an SD very similar or is it a completely different set of instructions?
I used one of the sketch examples from the examples and didn't modify anything but still not getting great results on the refresh. The page would load then after a few seconds page would time out for a few seconds.
Web Server
A simple web server that shows the value of the analog input pins.
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
* Analog inputs attached to pins A0 through A5 (optional)
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
modified 02 Sept 2015
by Arturo Guadalupi
#include <SPI.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
IPAddress ip(192, 168, 1, 177);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Ethernet.begin(mac, ip);
server.begin();
// listen for incoming clients
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println("Refresh: 5"); // refresh the page automatically every 5 sec
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(sensorReading);
client.println("
client.println("</html>");
if (c == '\n') {
// you're starting a new line
} else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disconnected");
