How to send HTTP request from one ESP8266 (master) to another (slave)
Hi all,
I have a working Wemos/Lolin D1 Mini running WiFiTerm (discussed here Remote terminal/monitor for ESP8266 & ESP32 - Libraries - Arduino Forum ).
I can send commands to it from any browser and control different local actions via a command line interface :
#include <ESP8266WiFi.h>
const char* ssid = "";
const char* password = "";
#include "WiFiTerm.h"
ESP8266WebServer server(80);
  pinMode(D1, OUTPUT);
  Serial.print("\nConnecting to WIFI");
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
    Serial.print('.');
  Serial.println("connected");
  Serial.print("IP address: ");
  server.begin();
  Serial.println("webServer started");
  term.begin(server);
  Serial.println("term started");
  server.handleClient();
  term.handleClient();
  if (term.available()) {
    incoming = term.readString();
    incoming.toUpperCase();
    term.println(incoming);
    uint8_t i = incoming.indexOf(' ');
    uint8_t j = incoming.indexOf(' ', i + 1);
    cmd = incoming.substring(0, i);
    p1 = incoming.substring(i + 1, j).toInt();
    p2 = incoming.substring(j + 1).toInt();
    //term.println(cmd);
    //term.println(p1);
    //term.println(p2);
    if (cmd == "TEST")
      digitalWrite(D1, 1);
    if (cmd == "ON")   // Turn on lamp
      // send HTML request to Sonoff S20 slave esp8266
What I could need som help with is how to execute a HTML request from this sketch to another ESP (which has a static IP address on my LAN). That would be a wifi controlled power outlet like this Reprogram Sonoff Smart Switch Web Server | Random Nerd Tutorials.
I can see in the sonoff sketch that a web page like this will be provided :
SONOFF Web Server
<a href="on">ON <a href="off">OFF
How can I send a HTTP "on" (or "off") command from the master to the slave ? I only need one way communication, the master can just throw away any web page element reply updates from the slave.
Thanks.
check out the BasicHttpClient example from ESP8266HttpClient
@Deva_Rishi
I will do that, thanks for your help !
