How to send IR code (if you have the Hex code)
hi i am new to Arduino.
i am busy with school project to control 1)Samsung and 2)AllianceAir Air conditioners.
i have received various AC codes for the AllianceAir 1) in RAW and also 2)Hex using IRrecvDump.
The problem is the RAW code is to much for the arduino (bout 56+ separate Raw signals, the arduno does not save and send more than 3 IR signals to the AC so i am stuck =( ). i have the Hex code which is much shorter but i dont know how to send “pure” hex code thru the IR LED (instead of the long RAW code).
How can i use the hex code that i have to send the IR Signal to the AC. please help?
For the AllianceAir AC some of the various codes below =
//Auto Alliance Poewr ON result:
CB40A279
Unknown encoding: CB40A279 (32 bits)
Raw (200): -8534 4300 -4350 550 -1550 550 -550 550 -1600 550 -1550 550 -550 550 -500 550 -1600 500 -550 550 -500 550 -1600 550 -550 500 -550 550 -1600 500 -1600 550 -550 500 -1600 550 -550 500 -550 550 -500 550 -1600 550 -1600 500 -1650 500 -1600 550 -1600 500 -1650 500 -1600 500 -1600 550 -600 450 -600 500 -550 500 -600 500 -550 500 -550 550 -550 500 -550 550 -500 550 -1600 550 -500 550 -550 500 -550 550 -1600 500 -1650 500 -1600 550 -1600 500 -550 550 -1600 500 -1600 550 -1600 500 -5200 4300 -4350 550 -1600 500 -550 550 -1600 500 -1600 550 -550 500 -550 550 -1600 500 -550 550 -500 550 -1600 550 -550 500 -550 550 -1600 500 -1600 550 -550 500 -1600 550 -550 550 -500 550 -500 550 -1600 550 -1600 550 -1500 600 -1600 600 -1550 500 -1600 600 -1600 500 -1600 550 -550 500 -550 550 -500 550 -550 500 -550 500 -550 600 -500 550 -500 600 -500 550 -1550 550 -550 500 -550 550 -500 600 -1550 600 -1500 650 -1550 500 -1600 550 -550 500 -1600 600 -1550 600 -1550 550
//Auto Alliance 18deg result:
38A59798
Unknown encoding: 38A59798 (32 bits)
Raw (200): 14694 4400 -4300 550 -1550 550 -550 550 -1550 600 -1550 550 -500 500 -600 550 -1550 600 -500 550 -500 550 -1600 550 -500 550 -550 550 -1550 500 -1650 550 -500 600 -1550 550 -500 600 -500 500 -550 550 -1600 550 -1600 500 -1600 500 -1650 550 -1600 550 -1550 600 -1550 550 -1600 550 -500 550 -550 550 -500 550 -500 550 -550 550 -500 550 -500 600 -500 550 -1550 600 -1550 550 -550 550 -500 550 -500 550 -1600 550 -1600 550 -1550 600 -500 550 -500 550 -1600 500 -1650 550 -1550 500 -5200 4300 -4350 550 -1550 550 -550 550 -1600 550 -1550 550 -550 550 -500 550 -1600 550 -500 550 -500 600 -1550 550 -550 550 -500 500 -1650 500 -1600 550 -550 500 -1600 550 -550 550 -500 550 -550 500 -1600 550 -1600 550 -1550 550 -1600 550 -1600 550 -1600 550 -1550 550 -1600 500 -550 600 -500 550 -500 500 -550 500 -600 550 -500 550 -500 550 -550 500 -1650 450 -1650 550 -550 550 -500 500 -550 550 -1600 550 -1600 550 -1600 450 -600 500 -550 550 -1600 500 -1650 550 -1550 550
//Auto Alliance 19deg result:
B92B4F58
Unknown encoding: B92B4F58 (32 bits)
Raw (200): 32754 4350 -4350 550 -1550 550 -550 550 -1550 550 -1600 550 -500 550 -550 550 -1550 550 -550 550 -500 550 -1600 550 -500 550 -550 550 -1550 550 -1600 550 -500 550 -1600 550 -500 550 -550 550 -500 550 -1600 550 -1600 550 -1550 550 -1600 550 -1550 600 -1550 550 -1600 550 -1550 550 -550 550 -500 550 -500 600 -500 550 -500 550 -550 550 -500 550 -1600 550 -1550 600 -1550 550 -500 600 -500 550 -500 550 -1600 550 -1550 600 -500 550 -500 600 -500 550 -1550 550 -1600 550 -1600 550 -5150 4300 -4350 550 -1550 550 -550 550 -1600 550 -1550 550 -550 550 -500 550 -1600 550 -500 550 -500 600 -1550 550 -550 550 -500 550 -1600 550 -1550 550 -550 550 -1550 550 -550 550 -500 550 -550 550 -1550 550 -1600 550 -1550 550 -1600 550 -1550 600 -1550 550 -1600 550 -1550 600 -500 550 -500 550 -550 550 -500 550 -500 600 -500 550 -500 550 -1600 550 -1600 550 -1550 550 -550 550 -500 550 -500 600 -1550 550 -1600 550 -500 550 -550 550 -500 550 -1600 550 -1550 550 -1600 550
