Hello, I am using two arduino nano with 433 Mhz transmitter and receiver
to make a wireless link between an anemometer and an lcd display.
I am using the VirtualWire library and it works great.
However, for the layout I programmed the micro controller connected
to the lcd display so that it permanently displays on the first line the
title "Wind Speed:"
followed by the value of the variable received by the serial port.
And it is he who positions the cursor at the desired location with the command
"lcd.setCursor (x, x);"
In short, there is only the variable which passes through the
serial / radio communication.
I'm looking for how to position the cursor or erase the content of the display
from the transmitter directly. So send commands (like "lcd.clear" or other ...)
through the serial link.
Thank you for your help.
//the variable "valeur" contain the wind speed value from an isr.
vw_send((byte *) &valeur, sizeof(valeur)); // On envoie le message
vw_wait_tx(); // On attend la fin de l'envoi
