how to send message multiples times rather than once
This is probably a very easy fix, but in my code I have messages sending to a can bus. I also have a menu system set up but when I chose a particular option, the message will only send once. I wanted to be able to specify how many times it sends.
Here is the section of code.
edit
This will send once. What can I change here to send it multiple times ?
Thanks
for(byte x=0;  x < numberOfTimes; x++)
//send message
delay(some);
I was going to suggest sending '1' as many times as you want to send the message. 8)
But, a for loop is working smarter, not harder.
That's what I was doing, but it wasn't very practical for what I was doing.
Thanks for the help!
Well you didn't show your whole sketch did you?
LarryD:
Sorry, my reply was to the other poster that suggested sending "1" multiple times.
Your solution of the for loop worked very well, thank you, much appreciated!
