Hi guys, I'm working on a gas leak detector project but I'm stuck on an implementation. In a few words, my equipment performs closing and opening at detection, I have managed to successfully make a call and many messages (8 or 10), but when implementing a function for only 1 message it stops sending messages. I'm not very skilled at programming so I'm probably leaving something out.
If anyone can give me a hand I will be very grateful, thanks in advance.
This is the last code I tried to make work.
int pin8 = 8;
int sensor = A0;
int sensorValue = 0;
const int buzzer = 5;
const int buttonPin = 7;
int buttonState = 0;
int gas = 0;
unsigned int current = 0;
unsigned int previous = 0;
unsigned long previousMillis = 0;
int currentIntervalIndex = 0;
const int intervals[] = {200, 500}; // Time intervals in milliseconds
// Variable for LED status
int ledState = LOW;
#include <SoftwareSerial.h>
//Create the serial software object to communicate with the SIM800L
SoftwareSerial mySerial(3, 2); // The SIM800L Tx & Rx pins will connect to the Arduino pins #3 & #2
unsigned long CallStartTime = 0; // Variable for the call timer
bool activeCall = false; // Call status
bool callDone = false;
bool messageSent = false;
//begins serial communication with Arduino and Arduino IDE (Serial Monitor)
//Serial communication with Arduino and SIM800L begins
mySerial.begin(9600);
Serial.println("Initializing...");
current = millis();
previous = current;
pinMode(buzzer, OUTPUT);
pinMode(pin8, OUTPUT);
pinMode(buttonPin, INPUT);
digitalWrite(pin8, HIGH);
gas = digitalRead(pin8);
buttonState = digitalRead(buttonPin);
SensorValue = analogRead(sensor);
// If the sensor value exceeds a threshold and there is no active call, activate the call
if (sensorvalue > 130 && !activecall && !madecall) {
digitalWrite(pin8, LOW);
activeCall = true; // Marks that the call is active
CallStartTime = millis(); // Initialize the call timer
mySerial.println("ATD+ +59177167799;"); // Change ZZ with the country code and xxxxxxxxxx with the number of digits of the phone
updateSerial();
// Controls the duration of the call (20 seconds)
if (activecall && (millis() - callStartTime >= 15000)) {
activeCall = false; // Marks that the call is no longer active
mySerial.println("ATH"); // Hang up
updateSerial();
callDone = true;
clearBufferSerial();
if (callMade && !messageSent) {
//begins serial communication with Arduino and SIM800L
mySerial.println("AT"); //once the tests are done successfully, an OK will be returned
updateSerial();
mySerial.println("AT+CMGF=1"); // Configuring text mode
updateSerial();
mySerial.println("AT+CMGS=\"+59177167799\"");//change ZZ country code and xxxxxxxxxxxx with phone number to sms
updateSerial();
mySerial.print("alert, gas detected"); //text content
updateSerial();
mySerial.write(26);
messageSent = true;
if (gas == LOW) {
// Get the current time
// Check if the current interval time has passed
if (currentMillis - previousMillis >= intervals[currentIntervalIndex]) {
// Save the current time as a reference for the next interval
// Change LED status
if (ledState == LOW) {
ledState = HIGH;
ledState = LOW;
// Apply state to LED
digitalWrite(buzzer, ledState);
// Advance to the next interval (cyclic)
currentIntervalIndex = (currentIntervalIndex + 1) % (sizeof(intervals) / sizeof(intervals[0]));
if ((sensorValue < 130) && (buttonState == HIGH)) {
callMade = false; // Any button pressed hangs the call
digitalWrite(buzzer, LOW);
void clearBufferSerial() {
while (Serial.available() > 0) {
char c = Serial.read();
void updateSerial() {
unsigned long currentTime = millis();
if (currentTime - previous >= 500) {
previous = currentTime;
while (Serial.available()) {
mySerial.write(Serial.read()); // forwards what the serial software port has received
while (mySerial.available()) {
Serial.write(mySerial.read()); // forward the received serial software to the serial port
If you need any other extra information, please tell me, I will keep and eye the whole day.
