How to send more than 28 bytes through nrf24l01
I too have same problem in getting data …from transmitter to receiver
Im using RF24 and RFNetwork library for sending data from large number of nodes to single master
I fragmented my 84 bytes array into 3 different 28 bytes array and sending it to master… but my master code can only read first 28 bytes…
HERE IS MY MASTER CODE:
#include <RF24Network.h>
#include <RF24.h>
#include <SPI.h>
RF24 radio(9, 8);
RF24Network network(radio);
const uint16_t Master_node = 00;
const uint16_t Slave_1_node = 01;
char incomingData[31];
unsigned long last_time = 0;
SPI.begin();
radio.begin();
network.begin(90, Master_node);
radio.setDataRate(RF24_250KBPS);
Serial.println(“LOOP STARTED”);
// delay(2000);
RF24NetworkHeader header1;
network.update();
// delay(50);
network.read(header1, &incomingData, sizeof(incomingData));
Serial.println(incomingData);
HERE IS MY SLAVE CODE:
#include <RF24.h>
#include <SPI.h>
RF24 radio(9, 8);
char incomingData[6];
String Received_cmd = “”;
byte status_flag = 1;
char received_data[83];
uint8_t index = 0;
char array1[31];
char array2[31];
char array3[31];
void getDatafromMega() {
digitalWrite(5, HIGH);
if (Serial.available() > 0)
char c = Serial.read();
if (c == ‘*’)
index = 0;
uint8_t i = 0;
for (i = 0; i < 84; i++)
received_data = ‘\0’;
  • else if (c == ‘#’)*
    memcpy(array1, received_data, 14 * sizeof(int));
    memcpy(array2, received_data + 28 , 15 * sizeof(int));
    memcpy(array3, received_data + 58 , 13 * sizeof(int));
  • status_flag = 0;*
  • else*
  • received_data[index] = c;*
  • index++;*
  • digitalWrite(5, 0);*
  • Serial.begin(9600);*
  • pinMode(5, OUTPUT);*
  • radio.begin();*
  • network.begin(90, Slave_1_node);*
  • radio.setDataRate(RF24_250KBPS);*
  • radio.enableDynamicPayloads();*
  • Serial.println(“begin loop”);*
  • if (status_flag == 0) {*
  • RF24NetworkHeader header1(Master_node);*
  • network.write(header1, &array1, sizeof(array1));*
  • delay(100);*
  • network.write(header1, &array2, sizeof(array2));*
  • delay(100);*
  • network.write(header1, &array3, sizeof(array3));*
  • delay(100);*
  • status_flag = 1;*
  • else if (status_flag == 1) {*
  • for (int i = 0; i < 6; i++) {*
    _ incomingData = ‘\0’;_
    * getDatafromMega();*
@hanishgopi, yours is a new question in a 6-years dead Thread so I have suggested to the Moderator to move it to its own Thread.
You have not said how far apart your Arduinos are - maybe the Network library is not necessary?
And to make it easy for people to help you please modify your post and use the code button </>
so your code
looks like this
and is easy to copy to a text editor. See How to use the Forum
...R
Simple nRF24L01+ Tutorial
@hanishgopi
TOPIC SPLIT.
Please don't HIJACK other posts and maybe READ THIS please.
Bob.
