How to send multiple HTTP requests to ardino web servers in one "click"?
My goal is the following:
To have several arduino ethernet shields in the same LAN each set up as a web server. I also have a web page locally on the computer with a frameset with the same number of frames as ethernet shields (web servers) in the network. Upon the start-up of the web page, a simple HTML page is loaded into each frame from each web server. Each page has just one or links used for turning on/off the LED on the corresponding arduino via HTTP requests.
I want to have one link (or button) for turning off (or on) all LEDs on all arduinos. So I am looking for the way how to "tell" all arduinos with one "click" to do so. Technically I see it as sending multiple HTTP requests to web servers in a sequence within a short period of time or at the same time.
I have searched different topics, but could not find this kind of solution. I even do not know if it is technically possible to do so.
What would be your recommendation to achieve this goal?
Many thanks! /churduino
JavaScript. Write a script that submits the forms in each frame.
I want to have one link (or button) for turning off (or on) all LEDs on all arduinos. So I am looking for the way how to “tell” all arduinos with one “click” to do so. Technically I see it as sending multiple HTTP requests to web servers in a sequence within a short period of time or at the same time.
You can embed your arduino command calls as links in a very simple web page that will activate the links when the page is loaded in a browser. On a main web page these various command pages can be called to a frame using simple link calls. The below code basically calls three different web pages from a main web page which are displayed in a frame.
// zoomkat's meta refresh data iframe test page 12/24/12
// use http://192.168.1.102:84 in your brouser for main page
// http://192.168.1.102:84/data static data page
// http://192.168.1.102:84/datastart meta refresh data page
// for use with W5100 based ethernet shields
// set the refresh rate to 0 for fastest update
// use STOP for single data updates
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // arduino ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
unsigned long int x=0; //set refresh counter to 0
String readString;
void setup(){
    // disable SD SPI if memory card in the uSD slot
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  server.begin();
  Serial.println("meta refresh data frame test"); // so I can keep track of what is loaded
void loop(){
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
         if (readString.length() < 100) {
          readString += c;
        //check if HTTP request has ended
        if (c == '\n') {
          //check get atring received
          Serial.println(readString);
          //output HTML data header
          client.println("Content-Type: text/html");
          client.println();
          //generate data page
          if(readString.indexOf("data") >0) {  //checks for "data" page
            x=x+1; //page upload counter
            client.print("<HTML><HEAD>");
            //meta-refresh page every 1 seconds if "datastart" page
            if(readString.indexOf("datastart") >0) client.print("<meta http-equiv='refresh' content='1'>");
            if(readString.indexOf("datafast") >0) client.print("<meta http-equiv='refresh' content='0'>");
            client.print("<title>Zoomkat's meta-refresh test</title></head><BODY>
            client.print("page refresh number ");
            client.print(x); //current refresh count
            client.print("
              //output the value of each analog input pin
             for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
             client.print("analog input ");
             client.print(analogChannel);
             client.print(" is ");
             client.print(analogRead(analogChannel));
             client.print("
            client.print("</BODY></HTML>");
          //generate main page with iframe
            client.print("<HTML><HEAD><TITLE>Zoomkat's frame refresh test</TITLE></HEAD>");
            client.print("Zoomkat's Arduino frame meta refresh test 2/20/13");
            client.print("
Arduino analog input data frame:
            client.print("&nbsp;&nbsp;<a href='http://192.168.1.102:84/datastart' target='DataBox' title=''yy''>META-REFRESH</a>");
            client.print("&nbsp;&nbsp;&nbsp;&nbsp;<a href='http://192.168.1.102:84/data' target='DataBox' title=''xx''>SINGLE-STOP</a>");
            client.print("&nbsp;&nbsp;&nbsp;&nbsp;<a href='http://192.168.1.102:84/datafast' target='DataBox' title=''zz''>FAST-DATA</a>
            client.print("<iframe src='http://192.168.1.102:84/data' width='350' height='250' name='DataBox'>");
            client.print("</iframe>
</HTML>");
          delay(1);
          //stopping client
          client.stop();
          //clearing string for next read
          readString="";
Thanks guys for your feedback and tips!
Zoomkat,
I have tested your code on my Arduino.
I have one question though.
How can I achieve this without clicking on each and very link? Each link will represent each node (IP and socket of each Arduino is listening on).
I can have several links on one page, but how can I activate all of them automatically when the page is refreshed in order to send multiple requests to all Arduinos?
Or do I misunderstand your suggested solution?
Thanks!
/churduino
I’d try embedding the command as an image link similar to the below, and the browser should send the request to the desired server. Also a redirect call to the desired server should also work. You will need to try various methods to see what works.
<img src="http://arduino.cc/forum/Themes/arduinoWide/images/home_icon.gif" alt="home icon" title=" home icon " width="9" height="11">
<meta http-equiv="Refresh" content="0; url=http://www.quackit.com/html/tags/">
http://www.w3schools.com/html/html_images.asp
http://www.w3schools.com/tags/att_img_src.asp
http://www.w3schools.com/html/html_videos.asp
http://www.quackit.com/html/html_redirect.cfm
