Hello,
I need some help explaining how to send and receive MPU6050 accelerometer data with Adafruit Feather M0 RFM69HCW Using the RFM69 Radio | Adafruit Feather M0 Radio with RFM69 Packet Radio | Adafruit Learning System
For now its Part I, how to send values.
Below is a demo sketch that is on Adafruit's learning page. I used it as a starting point. Sending HELLO WORLD works fine, the boards are talking.
#include <SPI.h>[color=#2e8b57][/color]
#include <RH_RF69.h>[color=#2e8b57][/color]
// Change to 434.0 or other frequency, must match RX's frequensy![color=#2e8b57][/color]
#define RF69_FREQ 915.0[color=#2e8b57][/color]
#define RFM69_CS 8[color=#2e8b57][/color]
#define RFM69_INT 3[color=#2e8b57][/color]
#define RFM69_RST 4[color=#2e8b57][/color]
#define LED 13[color=#2e8b57][/color]
// Singleton instance of the radio driver[color=#2e8b57][/color]
RH_RF69 rf69(RFM69_CS, RFM69_INT);[color=#2e8b57][/color]
int16_t packetnum = 0; // packet counter, we increment per xmission[color=#2e8b57][/color]
void setup()[color=#2e8b57][/color]
{[color=#2e8b57][/color]
Serial.begin(115200);[color=#2e8b57][/color]
//while (!Serial) { delay(1); } // wait until serial console is open, remove if not tethered to computer[color=#2e8b57][/color]
pinMode(LED, OUTPUT);[color=#2e8b57][/color]
pinMode(RFM69_RST, OUTPUT);[color=#2e8b57][/color]
digitalWrite(RFM69_RST, LOW);[color=#2e8b57][/color]
Serial.println("Feather RFM69 TX Test!");[color=#2e8b57][/color]
Serial.println();[color=#2e8b57][/color]
// manual reset[color=#2e8b57][/color]
digitalWrite(RFM69_RST, HIGH);[color=#2e8b57][/color]
delay(10);[color=#2e8b57][/color]
if (!rf69.init()) {[color=#2e8b57][/color]
Serial.println("RFM69 radio init failed");[color=#2e8b57][/color]
while (1);[color=#2e8b57][/color]
}[color=#2e8b57][/color]
Serial.println("RFM69 radio init OK!");[color=#2e8b57][/color]
// Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM (for low power module)[color=#2e8b57][/color]
// No encryption[color=#2e8b57][/color]
if (!rf69.setFrequency(RF69_FREQ)) {[color=#2e8b57][/color]
Serial.println("setFrequency failed");[color=#2e8b57][/color]
// If you are using a high power RF69 eg RFM69HW, you *must* set a Tx power with the[color=#2e8b57][/color]
// ishighpowermodule flag set like this:[color=#2e8b57][/color]
rf69.setTxPower(20, true); // range from 14-20 for power, 2nd arg must be true for 69HCW[color=#2e8b57][/color]
// The encryption key has to be the same as the one in the server[color=#2e8b57][/color]
uint8_t key[] = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08,[color=#2e8b57][/color]
0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08[color=#2e8b57][/color]
};[color=#2e8b57][/color]
rf69.setEncryptionKey(key);[color=#2e8b57][/color]
Serial.print("RFM69 radio @"); Serial.print((int)RF69_FREQ); Serial.println(" MHz");[color=#2e8b57][/color]
void loop() {[color=#2e8b57][/color]
delay(1000); // Wait 1 second between transmits, could also 'sleep' here![color=#2e8b57][/color]
char radiopacket[20] = "HELLO WORLD #";[color=#2e8b57][/color]
itoa(packetnum++, radiopacket + 13, 10);[color=#2e8b57][/color]
Serial.print("Sending "); Serial.println(radiopacket);[color=#2e8b57][/color]
// Send a message![color=#2e8b57][/color]
rf69.send((uint8_t *)radiopacket, strlen(radiopacket));[color=#2e8b57][/color]
rf69.waitPacketSent();[color=#2e8b57][/color]
// Now wait for a reply[color=#2e8b57][/color]
uint8_t buf[RH_RF69_MAX_MESSAGE_LEN];[color=#2e8b57][/color]
uint8_t len = sizeof(buf);[color=#2e8b57][/color]
if (rf69.waitAvailableTimeout(500)) {[color=#2e8b57][/color]
// Should be a reply message for us now[color=#2e8b57][/color]
if (rf69.recv(buf, &len)) {[color=#2e8b57][/color]
Serial.print("Got a reply: ");[color=#2e8b57][/color]
Serial.println((char*)buf);[color=#2e8b57][/color]
Blink(LED, 50, 3); //blink LED 3 times, 50ms between blinks[color=#2e8b57][/color]
} else {[color=#2e8b57][/color]
Serial.println("Receive failed");[color=#2e8b57][/color]
Serial.println("No reply, is another RFM69 listening?");[color=#2e8b57][/color]
void Blink(byte PIN, byte DELAY_MS, byte loops) {[color=#2e8b57][/color]
for (byte i = 0; i < loops; i++) {[color=#2e8b57][/color]
digitalWrite(PIN, HIGH);[color=#2e8b57][/color]
delay(DELAY_MS);[color=#2e8b57][/color]
digitalWrite(PIN, LOW);[color=#2e8b57][/color]
I understand that I would have to modify the lines in the loop and to change Hello World to call for accelerometer's values mpu6050.getAccX(); (as an example, from one of the libraries). I tried to change Hello World to accelerometer's code but no data is showing.
mpu6050.update();[color=#2e8b57][/color]
float acc = mpu6050.getAccX();[color=#2e8b57][/color]
char radiopacket[20] = {acc};[color=#2e8b57][/color]
Also, what does 20 in the square brackets mean? same for the line below, numbers 13 and 10?
char radiopacket[20] = "Hello World #";[color=#2e8b57][/color]
Thanks
