How to send sensor data(up to 16 sensors) from arduino to database
I am trying to send the sensor data from arduino to database using the WiFi shield and web client examples. But i failed to send any data inside database. Really needed help !
Post your program. Without that nobody can see what the problem is.
And please use the code button </>so your code looks like thisand is easy to copy to a text editor
...R
im using this codes. But then i realized every time i add another variabale inside, it will not execute the statement.
Which is this statement :
snprintf(address,sizeof(address),"GET /SIP16/Service1.asmx/InsertSensorValue?S0=%d&S1=%d&S2=%d&S3=%d HTTP/1.1",sensorValue0,sensorValue1,sensorValue2,sensorValue3);
  Repeating Wifi Web Client
 This sketch connects to a a web server and makes a request
 using an Arduino Wifi shield.
 Circuit:
 * WiFi shield attached to pins SPI pins and pin 7
 created 23 April 2012
 modified 31 May 2012
 by Tom Igoe
 modified 13 Jan 2014
 by Federico Vanzati
 http://www.arduino.cc/en/Tutorial/WifiWebClientRepeating
 This code is in the public domain.
#include <SPI.h>
#include <WiFi.h>
#include <String.h>
char ssid[] = "PotatoNet";      //  your network SSID (name)
char pass[] = "2014vvvv";      // your network password
//int keyIndex = 0;            // your network key Index number (needed only for WEP)
int sensorPinA0 = A0;
int sensorPinA1 = A1;
int sensorPinA2 = A2;
int sensorPinA3 = A3;
int sensorPinA4 = A4;
int sensorPinA5 = A5;
char address[100];
const char* host = "http://172.20.34.48";
  int sensorValue0;
  int sensorValue1;
  int sensorValue2;
  int sensorValue3;
int status = WL_IDLE_STATUS;
// Initialize the Wifi client library
WiFiClient client;
// server address:
IPAddress server(172,20,34,48);
unsigned long lastConnectionTime = 0;            // last time you connected to the server, in milliseconds
const unsigned long postingInterval = 10L * 1000L; // delay between updates, in milliseconds
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // check for the presence of the shield:
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    // don't continue:
    printWifiStatus();
    while (true);
  String fv = WiFi.firmwareVersion();
  if (fv != "1.1.0") {
    Serial.println("Please upgrade the firmware");
  // attempt to connect to Wifi network:
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  // you're connected now, so print out the status:
  printWifiStatus();
  // if there's incoming data from the net connection.
  // send it out the serial port.  This is for debugging
  // purposes only:
  while (client.available()) {
    char c = client.read();
    Serial.write(c);
  // if ten seconds have passed since your last connection,
  // then connect again and send data:
  if (millis() - lastConnectionTime > postingInterval) {
    httpRequest();
// this method makes a HTTP connection to the server:
void httpRequest() {
  // close any connection before send a new request.
  // This will free the socket on the WiFi shield
  client.stop();
  // if there's a successful connection:
  if (client.connect(server, 80)) {
    Serial.println("connected to server NEW");
 // read the input on analog pins:
   sensorValue0= analogRead(sensorPinA0);
   sensorValue1 = analogRead(sensorPinA1);
   sensorValue2 = analogRead(sensorPinA2);
   sensorValue3= analogRead(sensorPinA3);
     // print out the value you read:
    Serial.print("Sensor 0 :");
    Serial.print(sensorValue0);
    delay(10);
    Serial.print("\t Sensor 1 :");
    Serial.print(sensorValue1);
    delay(10);        // delay in between reads for stability
    Serial.print("\t Sensor 2 :");
    Serial.print(sensorValue2);
    delay(10);
    Serial.print("\t Sensor 3 :");
    Serial.println(sensorValue3);
    delay(10);
  /*  Serial.print("\t Sensor 4:");
    Serial.println(sensorValue4);
    delay(10);
    Serial.print("\t Sensor 5:");
    Serial.println(sensorValue5);
    delay(10); */
  // send the HTTP PUT request:
    client.println(address);
    client.println("Host: 172.20.34.48");
    client.println("User-Agent: ArduinoWiFi/1.1");
    client.println("Connection: close");
    client.println();
    Serial.println("Upload data...");
    // note the time that the connection was made:
    lastConnectionTime = millis();
    // if you couldn't make a connection:
    Serial.println("connection failed");
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
Yes you'll have to add more arguments to the snprintf, that's easy enough though? Is the issue
that the server doesn't understand the longer request?
Yes. I guess the server doesn't understand longer request. What do you mean by adding more arguments to the snprintf? Im not sure how to do it.
