how to send serial data from arduino to esp8266
I want to make a project where data is sent from esp826-01 to Arduino Uno R3, I previously made it using the code below but failed.
For ESP8266-01
#include <SoftwareSerial.h>
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#define BAUD_RATE 9600
SoftwareSerial swSer(14, 12, false, 256);
// Replace with your network credentials
const char* ssid     = "farzain_2";
const char* password = "1999fzyc";
  Serial.begin(BAUD_RATE);
  swSer.begin(BAUD_RATE);
  WiFi.begin(ssid, password);
  while(WiFi.status() != WL_CONNECTED) {
  String IncomingString = "";
  boolean StringReady = false;
  while(swSer.available() > 0) {
    IncomingString = swSer.readString();
    StringReady = true;
    yield();
  if(StringReady) {
    if(IncomingString == "on") {
      HTTPClient http;
      http.begin("https://if.farzain.com/add_uno.php?add=1");
      Serial.println("OK");
For Arduino UNO R3
SoftwareSerial mySerial(1,0); //RX, TX
  Serial.write("ON");
  Serial.write("OFF");
how to fix it? thank you
how to post an image.
Your sketches show data sent from the Arduino to the ESP, so what are you actually trying to do.
Why do you have software serial on the hardware serial pins of the Uno? You never call software serial in the sketch but if you did, it wouldn't work properly.
Regarding the ESP8266
It would be preferable to use the hardware serial UART0 which is mapped to pins GPIO1 (TX) and GPIO3 (RX). on the ESP.
You should do some Google search on "Arduino serial communication with ESP 8266-01"
You might also consider the need for level shifting the Tx>Rx of the 5v uno to the 3.3v esp.
Your wiring diagram with Tx>Tx and Rx>Rx looks like it might be for downloading code to the esp and not for operating.
If you are new to Arduino and ESP8266 you might be better off with a complete esp8266 module with USB like the Wemos , Node MCU or Feather HUZZAH. They are much more simple to use than the -01 module.
