How to send temperature with NRF24L01
Hi, I'm a newbie for Arduino. I have a problem with sending temperature between nrf24l01
who can give me a code TT(TX,RX libaries and how to connect pin with Uno R3) and explain how it work? i'm stuck with this about 2 week. help me plasessss
this is a place to start: Arduino Playground - Nrf24L01
If u cannot solve this:
Download the mirf-library, unpack it in the library-folder where arduino is installed..
restart the IDE.
Connect as comments in the code shows..:
Run this code on transmitter:
 * SENDEREN / TRANSMITTER
 * Hardware SPI:
 * Radio MO -> Arduino pin 11 (MOSI)
 * Radio MI -> Arduino pin 12 (MISO)
 * Radio SCK-> Arduino pin 13 (SCK)
 * options:
 * Radio CE -> Arduino pin 8 (default - kan endres/can be altered)
 * Radio CSN-> Arduino pin 7 (default - kan endres/can be altered)
#include <SPI.h>
#include <Mirf.h>
#include <nRF24L01.h>
#include <MirfHardwareSpiDriver.h>
#include <MirfSpiDriver.h>
const byte payload=10; // max 32
union {
  byte ch[payload];
  int val[payload/2];
} buffer; // buffer for 10 bytes => 5 analog values
    Mirf.csnPin = 7; // kan endres etter behov. Kan utelates hvis default
    Mirf.cePin = 8; // kan endres etter behov. Kan utelates hvis default
    Mirf.spi = &MirfHardwareSpi;
    Mirf.init();
    Mirf.payload = payload;
    Mirf.channel=110; // any channel:  1..120
    Mirf.config();
   Mirf.setTADDR((byte *)"team1");
   for (int i=0;i<5;i++)  buffer.val[i]=analogRead(i); // analoRead pin A0..A4
   Mirf.send(buffer.ch); // or one can use:  Mirf.send((byte *)&buffer);
   while (Mirf.isSending()){}; // waut for data sent / vent til data er sendt
   delay(200); // pause - thin of receiver capacity to handle incoming data
and this on your receiver
 * Dette er MOTTAKEREN / RECEIVER
 * Hardware SPI:
 * Rasio MI -> Arduino pin 12 (MISO)
 * Valgvare:
 * Radio CE -> Arduino pin 8 (dette er defaultverdier. kan endres)
 * Radio CSN-> Arduino pin 7 (dette er defaultverdier. kan endres)
#include <SPI.h>
#include <Mirf.h>
#include <MirfSpiDriver.h> //uvisst hva denne gjør !!
union {
  byte ch[payload];
  int val[payload/2];
    Mirf.init();
    Mirf.channel=110; // match sender
    Mirf.config();
   Mirf.setRADDR((byte *)"team1"); //  nettnavn=nettadresse
   while(!Mirf.dataReady()){}; // vent til data er mottatt
   Mirf.getData(buffer.ch); // or   Mirf.getData((byte *)&buffer);
   for (int i=0; i<5; i++)
     Serial.print(buffer.val[i]) ;
     Serial.print("\t");
Thank you very much,It's work. But there have some error ex. when dht11(at tx) get temperature 32 c but rx recive 8 c, I don't know why ,and humidity has also same problem.(sorry for my eng. skill)
post link to the library - and the code for the tansmitter
I found this one ? GitHub - adafruit/DHT-sensor-library: Arduino library for DHT11, DHT22, etc Temperature & Humidity Sensors
uses float, which requires 4 bytes, compiled for an "uno"
solve this by changing datastructure.
for transmitter: complete example:
 * Hardware SPI:
 * options:
#include <SPI.h>
#include <Mirf.h>
union
  byte ch[payload]; // 10 bytes
  struct
    float temp; // 4 bytes
    float humi; // 4 bytes
    int extra; //  2 bytes
    Mirf.init();
    Mirf.config();
   buffer.temp=25.2; //example.. read from dht11
   buffer.humi=40.5; //example.. read from dht11
same change for reveiver.
Thank you again, humidity work pretty fine but temp is not (ex.ght11 get 25c and send but rx get8.50)how can i fix this or must i connect capacitor to the nrf24l01.
