How to send two parameters
char id = 'usa008mn';
int x = digitalRead(LED_BUILTIN);
client.print(id + '/' + x);
bust output as below:
157
157
I want the format "usa008mn/1"
.png
Because.
This is just a snippet of my full answer
char id = 'usa008mn'; eight into one don't go.
Please remember to use code tags when posting code
What does your calculator show when you try to add those three values?
pls see attach :157
i want to how to solve my question? thanks a lot.
You're adding three two ASCII character values and a single digit value together and getting a perfectly valid result.
I don't see the problem
Instead of this
do this
client.print(id);
client.print('/');
client.print(x);
...R
... but make sure "id" is what you think it is.
