How to send values over Artnet
Hey,
I'm relative new to coding in C and I want to send DMX values over Artnet from the arduino. I used the Artnet examples to receive DMX values and it's just worked fine, but I can't figure out how to send data.
This is the example code I tried to use:
// Please include ArtnetWiFi.h to use Artnet on the platform
// which can use both WiFi and Ethernet
#include <ArtnetWiFi.h>
// this is also valid for other platforms which can use only WiFi
// #include <Artnet.h>
// WiFi stuff
const char* ssid = "your-ssid";
const char* pwd = "your-password";
const IPAddress ip(192, 168, 1, 201);
const IPAddress gateway(192, 168, 1, 1);
const IPAddress subnet(255, 255, 255, 0);
ArtnetWiFiSender artnet;
const String target_ip = "192.168.1.200";
uint32_t universe = 1;
const uint16_t size = 512;
uint8_t data[size];
uint8_t value = 0;
    // WiFi stuff
    WiFi.begin(ssid, pwd);
    WiFi.config(ip, gateway, subnet);
        Serial.print(".");
    Serial.print("WiFi connected, IP = ");
    artnet.begin();
    // artnet.begin(net, subnet);     // optionally you can change net and subnet
    value = (millis() / 4) % 256;
    memset(data, value, size);
    artnet.streaming_data(data, size);
    artnet.streaming(target_ip, universe);  // automatically send set data in 40fps
    // artnet.streaming(target_ip, net, subnet, univ);  // or you can set net, subnet, and universe
My arduino connects to wifi correctly but I didn't get an output, even when I change the value variable. I looked at all Universes, but I didn't found any changed values
