How to sense that an object is in place
The short of it is that I have a machine that needs to know when a cup, or other drinking vessel, has been placed into a chamber. The chamber is about 6 inches square and cups are placed into the middle. What kind of sensor would be best for this sort of thing? I was thinking some sort of "electric eye" that can tell when a light has been interrupted but I don't know what kind of sensor does this. Any guidance is appreciated!
A photoresistor (also called LDR or light dependent resistor) would probably work, although you may need to provide a light beam that the cup interrupts. http://playground.arduino.cc/Learning/PhotoResistor There are also photodiodes and phototransistors, with lots of tutorials for each.
I would use capaciency if i were you. I believe there is a library for this here http://playground.arduino.cc/Main/CapacitiveSensor?from=Main.CapSense
Here is a project using it that I pulled up really quick. http://www.bareconductive.com/capacitance-sensor.
Depending on the weight of the cups/drinking vessels, why not use good old non latching switches?
Something similar to the attached diagram.
I have drawn the chamber as a square (simply because it’s easier to draw it like that) but a tubular shape would work even better.
Anyhow it’s simply to illustrate the idea.
I like that switch idea a lot. I need something with super minimal coding required, there isn't a lot of room left.
ncivitello: I like that switch idea a lot.
As long as the containers are heavy enough to reliably push down the switch, it will work nicely. The small pcb mount switches need very little force to work.
You can't get simpler than reading switches. Just remember to do a bit of debouncing, either via a capacitor and resistor or in software. Unless you have other bits of code that can't tolerate blocking code, the software debounce could be as simple as waiting (or polling) for a switch to be triggered, wait another 100mS or so and check it's state again.
