AIM OF MY GRADUATION PROJECT: To build an autonomous real time device to measure the physical and chemical parameters of water using Arduino(an open-source physical computing platform based on a simple microcontroller board, and a development environment for writing software for the board.) Atmega 2560 Microcontroller.
HARDWARE TOOLS FOR MY PROJECT:
Arduino Atmega 2560 development board
4x4 Matrix Keypad
16x2 LCD
Series 2 Zigbee Pair
Physical & Chemical Water Parameters Sensors(Ph Sensor, Conductivity, Dissolved Oxygen, Temperature and level sensor)
I'm being working on ARDUINO ATMEGA 2560. Can anyone help me with the programming part of sensing the sensor value and displaying it onto the LCD?
You need to first communicate with the sensors you have using any of the communication protocols they use like the i2c, one wire, spi ,uart , analog etc and then you need to process the extracted data into information then convert the value in string to be loaded into the print method of the LCD.
